Author Topic: My Dragon Green 8V GTI...work in progress  (Read 6362 times)
Offline Callum_K
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: My Dragon Green 8V GTI...work in progress
« Reply #11 on: 14 October 2012, 23:00 »
Not opening properly for some unknown reason.
« Reply #12 on: 14 October 2012, 23:32 »
It says 93 to 97 but the changed the front spring sizes so you may need to check the size of the new springs before ordering you lowering caps.
Offline Callum_K
« Reply #13 on: 15 October 2012, 11:47 »
The springs are definitely the later ones with the smaller diameter top. FK do two spring caps, up to 07/93 and after 08/93, so will order the latter.
« Reply #14 on: 15 October 2012, 13:29 »
Are you thinking of replacing the shocks as well, might be worth thinking about.
Offline Callum_K
« Reply #15 on: 15 October 2012, 14:00 »
I expect I will at some point, or may even get a decent set of coilovers. For the moment however I'm being cheap and it will just be the springs, with only a 20mm drop hopefully it shouldn't ride to bad on the standard shocks.
« Reply #16 on: 15 October 2012, 21:17 »
It will be crap on the standard shocks they are underdamped at the best of times, save a little more and fit a new set of gas shocks will be worth it in the long run.
« Reply #17 on: 15 October 2012, 21:50 »
Defo, they really are sh!te.
Offline Callum_K
« Reply #18 on: 16 October 2012, 09:25 »
Lol okay, may rethink that then. They were only £20 so it's not really a big deal if I don't use them. Will do some research into decent coilies or a spring/shock combo. Ideally no more than £300.
« Reply #19 on: 16 October 2012, 10:07 »
NB. The standard issue oil filled struts are dire, not your new springs as we don't know their origin. :wink:
