Author Topic: G60 Brake Upgrade Pad Problems???  (Read 3404 times)
Offline jakethesnake180
« on: 08 October 2012, 23:27 »
Began putting the front end of my project 16v back together over the weekend.
However . . . . . . G60 carriers fitted with new Apec discs and new Apec pads.
Attempted to refit the 16v calipers only to find they wouldnt go over the pads,
To be accurate the caliper is just wide enough to slide over the disc and pads but fouls on the sliders.
Made sure the piston was pushed right back but still no joy.
It seems that the pads / disc is a couple of mm to thick causing my problem.
I have measured the thickness of the pads at 16mm from outside of metal backing to pad surface.
Has anyone come across this before when doing the upgrade? Am I missing something obvious?
Jake
Offline JamesS
Re: G60 Brake Upgrade Pad Problems???
« Reply #1 on: 10 October 2012, 17:48 »
Don't know your exact problem but I have heard when mixing mk2 brake parts with G60 stuff you may need to use thinner pads, not sure what model they are from though. Good luck!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Gambit
« Reply #2 on: 10 October 2012, 21:28 »
256mm calipers run a 20mm thick disk
280mm calipers run a 22mm disk
if you run 256mm calipers with 280mm carriers and disks you need to skim some meat of the pads
Offline Gambit
« Reply #3 on: 10 October 2012, 21:36 »
Offline clipperjay
« Reply #4 on: 13 October 2012, 18:37 »
There are two types of G60 pads one is defo thinner  :wink:
Give euro carparts to confirm.
 I remember having two boxesfor viewing for the G60 pads so all I did was bring in the disc and caliper and mock fitted on there desks LOL  :laugh:
« Reply #5 on: 13 October 2012, 20:48 »
Problem Solved!
Gambit you were right mate,
I now have G60 carriers fitted with 22mm thick G60 discs
16V calipers with shaved down G60 pads. (2mm approx off the outer, inner was fine)
The info that i found says the 16v pads are thicker than the 16mm G60 pads but I still had to shave them down.
Cheers Everyone
Offline Mk2_tel
« Reply #6 on: 14 October 2012, 08:04 »
I found with my g60 upgrade the g60 pads were too thick there the same as 16v yet 16v ones were thinner so put them on and everything was sweet
Offline sprout99
« Reply #7 on: 19 October 2012, 21:10 »
You actually need to turn the end of the slide pins down and use 16 v. Pads on hybrid 280mm upgrade. Been there on my valver
 :whistle
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Gambit
« Reply #8 on: 19 October 2012, 21:43 »
Thats only if ya wanna run them under std bbs ra's
Offline sprout99
« Reply #9 on: 21 October 2012, 21:21 »
that was my goal  :cool:
Oak green mk2
V50 D5 Sportwagon
