Author Topic: Fitted new wheels now have a droning noise ?  (Read 3021 times)
Offline spudboy6
  • Just like a golf ......
« on: 08 October 2012, 19:31 »
So i swappe my sport raders for vw standard estorils wheels .
All balanced correctly and wheels fitted and torqued up to the correct tightness .
On certain road surfaces the droning is worse than other but its there always but quiet sometimes . Have got hedge finders on ....
Almost sounds like a wheel bearing on the way out but weird just as I change the wheels and had an mot - passed :) .
Any ideas ??
Offline Screech16v
  • MK3 20vt AGU
Re: Fitted new wheels now have a droning noise ?
« Reply #1 on: 08 October 2012, 19:48 »
probably the tyres .
Offline spudboy6
« Reply #2 on: 08 October 2012, 19:54 »
Think the answer is toyo t1r's :)
Ill double check my wheel torqued tommrrow , have paranoia after someone said freshly painted wheels around the stud holes can work lose because of the fresh paint
All in my head :)
Offline tweed
« Reply #3 on: 08 October 2012, 20:03 »
I went from 205/50/15 to 195/40/16 and was shocked on how firmer and louder it is.
Are they same size?
Could be rubbing?
Offline spudboy6
« Reply #4 on: 08 October 2012, 20:07 »
Went from 185/60/40  to  195 50 15 . Done the math and the wheel circumstance is slightly less than the 14" set up . So shouldn't be but will check dropped 60/40
Have got wheel dice valve caps I it makes any difference ....
« Reply #5 on: 08 October 2012, 22:04 »
With alloys you should check them a few days after fitting and then again at 500miles.
Offline spudboy6
« Reply #6 on: 08 October 2012, 22:13 »
Will do thanks Wayne lucky I have a torque wrench !
Update anyways
Its not tyre noise I'm 100% , kicks in at 50mph and gets louder as you go on , it's like a whiring washing machine . I think a wheel bearing or drive shaft ,
« Reply #7 on: 08 October 2012, 22:14 »
Did it make the noise with the old wheels ?
Offline spudboy6
« Reply #8 on: 08 October 2012, 22:21 »
No literally started when I fitted the new wheels  , the wheels are all true I checked them on a wheel balancer before I spent the time refurbishing , so must have a flat spot on a tyre ?
« Reply #9 on: 09 October 2012, 10:51 »
Does sound that way tbh
