Author Topic: Codes from yesterday  (Read 1780 times)
Offline topher
  • Administrator
  • fully functioning
Re: Codes from yesterday
« Reply #10 on: 11 October 2012, 20:37 »
pretty sure you don't need to wipe the code, it will just go intermittent and be stored in the ecu. either the used part is buggered or you have a wiring issue
http://i284.photobucket.com/albums/ll5/nick225tt/cps.jpg
Offline Dalo Harkin
« Reply #11 on: 12 October 2012, 08:30 »
They reckon I need this:-
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=06A+906+433L&_sacat=0&_from=R40
Its a PITA trying to diagnose, it starts fine, a little rough only when you rev it and then it pops and splutters and the ECL light comes on, sounds like its struggling to keep running
Offline Dalo Harkin
« Reply #12 on: 13 October 2012, 09:03 »
thought I would add this incase anyone else gets the same issue:-
unplugged all the connectors including throttle body, inlet mani sensor, and camshaft sensor checked wiring all ok, so decided  to clean the throttle body while I was there, relaced all the sensor wires and car has been fine  :huh:
will check for codes again today and see whats disappeared
