Author Topic: r32 style dash trim fitting  (Read 1769 times)
Offline cooki
  • 1.8T AUM
« on: 07 October 2012, 10:42 »
few questions realy guys.
ive read all the fitting guids so got a good idea but still unsure on a few bits.
are the ashtray covers easily swapped over or do i need a hole ashtray?
how do u remove the radio side panels? (down and oit ive read).
also mines a 4 door so do the wooden inserts just pop out of the handles and i just stick the ali ones in with sumthin?
cheers guys :)
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: r32 style dash trim fitting
« Reply #1 on: 07 October 2012, 10:53 »
cheers guys :)
Hi mate I don't know about the ashtray cover but I would like to find out myself  :grin: as for the wooden inserts, they are glued in place and need to be pulled out, I broke mine when I got them out so be careful, the best way is to get a knife and try and cut your way along it, I found this out way too late ha ha, unless anyone else has any ideas?  :huh:
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 07 October 2012, 11:32 »
you should get the handle inserts in new handles
Offline SI74
« Reply #3 on: 07 October 2012, 12:30 »
Remove your Ashtray and then just pop the face part off. 1min job changing them over.
Offline cooki
  • 1.8T AUM
« Reply #4 on: 07 October 2012, 13:28 »
tar for the info guys.
only got the 3 inserts for the handles then the hole drivers side handle with window switches in.
ashtray sounds easy enough.
just the radio cage strips i need to work out now???
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #5 on: 07 October 2012, 14:40 »
Some side radio cage trim bits slide down and pop off, others the whole radio cage is to come out. :)
Offline cooki
  • 1.8T AUM
« Reply #6 on: 07 October 2012, 16:05 »
how can i find out if i have to take the hole radio cage out or not mate??any ideas?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 07 October 2012, 16:51 »
If they are wood they will be the type that come off without needing to pull the cage out
Offline SI74
« Reply #8 on: 07 October 2012, 17:08 »
Yea as above what trim is in the car?
Offline cooki
  • 1.8T AUM
« Reply #9 on: 07 October 2012, 18:23 »
thats good news then.
 yep its wood trim thats fitted now and im fitting my net optics thats been r32 ali style sanded.
so do i just try prize the side trim pannels down and out towards me??
