Author Topic: 16v tuning  (Read 4258 times)
Offline tshirt2k
  • Been there...Done that...
Re: 16v tuning
« Reply #10 on: 09 October 2012, 10:15 »
It would. But when people tuning them for best response. It's usually rich. Global timing is also adjusted. This base setting can usually be between 6-10 deg. Depending on engine.
3.5CO% is the limit on mk2 for MOT.
Mk3 ABF 16VT Megasquirt V3
Offline Gambit
Re: 16v tuning
« Reply #11 on: 09 October 2012, 10:26 »
again where are you getting all this from? and are you certain its for K-jet cars?
kjet 16v's run lean at higher rpm's, if increasing the mixture is an attempt to get round this then its a cheap way to do it
global base timing is set by increasing it until it pinks then backing of slightly. 16v is 8degrees as standard depending on the quality/ron of the fuel used you have window either side so that would explain your 6-10degree
Offline tshirt2k
Re: 16v tuning
« Reply #12 on: 09 October 2012, 12:05 »
Again! Why question it?
Yes for kjet! And timing is 6 deg standard :wink: take a look at the map below. 8 degrees will probably shift timing for better performance. They run up top end and WUR mod is a crude way to compensate for this. The info comes from someone who regularly tests the EA827 16v engine on a dyno in many configurations and I trust their judgement. I'm not suggesting anything other than running on +97RON fuel. I have seen written that people have used 10 deg. Unsure what spec of engine.
I'm not interested particularly in kjet. It does the job but a standalone system beats it by far.
« Last Edit: 09 October 2012, 12:09 by tshirt2k »
Offline Gambit
Re: 16v tuning
« Reply #13 on: 09 October 2012, 12:17 »
the reason im questioning it because i have never heard tell of anyone running 6.0% on kjet, nor have i seen any information to back this up. i assume you are quoting Toyotec of the main clubgti.com site?
Offline tshirt2k
Re: 16v tuning
« Reply #14 on: 09 October 2012, 14:39 »
I seem to recall the figure being that high, I may have misquoted. I can't seem to find where it was mentioned. This is due to adjusting for "feel" rather than figures.
Emissions are not always a concern with friendly MOT places.
Offline danny_p
Re: 16v tuning
« Reply #15 on: 10 October 2012, 22:03 »
1st step of K jet tuneing
make sure the injectors actualy atomise the fuel.
2nd step equlise the flow of injectors,  amazing how far out some of them are
3rd step make sure the WUR actualy works and do basic sytem setup
some people rediscover 20+ BHP there
as for running it very rich,  if you can get more spark advance on by doing it and it pulls harder for it  do it ( if your no fussed about economy )
all the VW's have gone bar 1.
Offline tshirt2k
Re: 16v tuning
« Reply #16 on: 11 October 2012, 10:19 »
Yep and that! In search of more power you don't tend to think of how much economy you'll get.
