Author Topic: Process of coolant change?  (Read 1473 times)
Offline robo22sri
« on: 21 September 2012, 22:23 »
My rad hoses are shot on my vr so bought new samco hoses
I am going to replace the oil cooler, water pump and expansion bottle at the same time, hoping the rad is not shot
Do I need deionised water when refilling after flushing all the block and matrix with a hose?
Cheers Rob
Any other tips will be great
Offline GOLF-MK3-GTI
Re: Process of coolant change?
« Reply #1 on: 21 September 2012, 23:26 »
Try not to round off the water pump bolts, I think there are 3 that hold the water pump, if you slip, it'll make things alot hard, as I have experienced in the past, apart from that, good luck :cool:
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #2 on: 11 October 2012, 19:29 »
Use  VW G 12 Coolant.
Offline leigh_harty
  • Audi AGU
« Reply #3 on: 11 October 2012, 20:46 »
Im sure you need to undo a mount or 2 and raise the engine up to remove the pump?
removal of the oil cooler is easy as, make sure you have newspaper down for obvious reasons  :smiley:
Dont lose your dinosaur!
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #4 on: 11 October 2012, 21:04 »
What he said ^^
First remove your air box and aux/serpentine belt. Take the bolt out of the rear, driver side engine mount, put a block of wood between your jack and your sump and jack the engine at the driver side about 4-5 inches, don't worry, the sumps are steel and won't bend  :huh: :wink:
This should give you enough clearance to remove the water pump  :cool:
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 11 October 2012, 21:09 »
Ahh so no undoing the front mount then :smiley:
Will be doing mine when I can be bothered  :grin:
On a related note can you get metal propeller pumps? Even worth it? I know they are an important upgrade on E36 bimmers
  • Golf MK3 GTD
« Reply #6 on: 11 October 2012, 21:42 »
Also very important,some people forget, turn to heating inside the car.
