Author Topic: difference between vento and golf  (Read 3433 times)
Offline Walkerboy
« on: 19 September 2012, 16:17 »
ok..............
obviously vento is a mk3 golf saloon,but is there any difference in a golf driveshaft ect than a vento one???
also subframe,rear beam
cheers
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: difference between vento and golf
« Reply #1 on: 19 September 2012, 17:10 »
Besides body differences the mechicanical parts are all same as far as I know. Only mechinal difference I can see is that exhaust rear silencer is longer.
I've had two Vento's.. a 1.8 and a VR6, going from memory but someone correct me if I'm wrong.
« Last Edit: 19 September 2012, 17:11 by Golf_GT_TDI »
Offline Walkerboy
« Reply #2 on: 21 September 2012, 22:21 »
has a vento got the same rear beam as a golf??
« Reply #3 on: 22 September 2012, 21:43 »
Yes but all Vento's apart from the VR were 4 stud.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 22 September 2012, 21:46 »
Beam would be the same though wouldn't it, just the stub axles and brake assemblies different surely?
« Reply #5 on: 22 September 2012, 21:48 »
I think so but VR and GTI Golfs had the wider track set up so I am not 100% sure if the beam is the same.
Offline tweed
« Reply #6 on: 22 September 2012, 22:15 »
Pretty sure the golf gti and vr6 has a narrower beam but the rear disc setup gives the wider track.
I looked into this as I want a low et wheel that tucked in the arch. I was going to swap beams but found out I had the narrow one to start with lol
Offline Walkerboy
« Reply #7 on: 23 September 2012, 18:43 »
what about if the beam,brakes engine was a vr golf and was going on a vento.
Change the whole lot over???
Offline tweed
« Reply #8 on: 24 September 2012, 03:58 »
That's what I would do.
It's easier for a start
Offline Walkerboy
« Reply #9 on: 30 September 2012, 19:38 »
awesome.lol
