Author Topic: 19" wheel arch lips?  (Read 7854 times)
Offline The rock
Re: 19" wheel arch lips?
« Reply #20 on: 25 September 2012, 16:52 »
mmmmm see what you ean . bet they d still look ace , especially on your white
Offline dubber36
« Reply #22 on: 25 September 2012, 18:39 »
They are horendous.
Offline Ginge 35Edition
« Reply #23 on: 27 October 2012, 17:50 »
Right, first of all sorry for digging out an old thread but I've finally got the part numbers for the rear wheel arch extension cos if I'm going to do them I may as well do them while fitting the rear spacers.
Sunday driver - thanks again for the pics provided, are they both the front or is one of them the rear? I can see a torque screw holding the arch lining in place, just wondering if the extension uses this one to hold both the extension and the lining? If they're not the rear any chance someone with an R might be able to get a half decent picture?
Just in case anyone one wondering the part is £10.60 inc vat per side.
Neil
Offline Murrayedition35
« Reply #24 on: 27 October 2012, 18:00 »
post up the photos once fitted and the part number... :smiley:
« Reply #25 on: 27 October 2012, 18:40 »
Forget my last post guys n girls as I've just had a thought. ETKA show you needing an additional screw for the fronts but not for the rear so it must use the location as described above. So these are now on order via stealer.
Part numbers:-
Trim wheel cover left rear 5K0 807 833
Trim wheel cover right rear 5K0 807 834
ETKA illustration 807-50 item 30
« Last Edit: 27 October 2012, 18:46 by Ginge 35Edition »
