Author Topic: 1.8T AGU k04 conversion help  (Read 11672 times)
Offline barrym381
Re: 1.8T AGU k04 conversion help
« Reply #30 on: 19 September 2012, 16:06 »
ah sh!t! never realised u had a a3 quatro!
i dont wana see it!  :lipsrsealed: it will make me want another! and i really dont wana  :embarrassed:
got a cheap 1 here for you toby  :grin:
Offline Toby
  • Car - less
« Reply #31 on: 19 September 2012, 16:47 »
BMW 335i! I'm still holding out  :laugh:
Currently down under
Offline optispart
« Reply #32 on: 19 September 2012, 17:34 »
interesting so the tt injectors may be ok? if so all id need is relentless mani where can i find one!!! lol
mk4 monster starts here
Offline Chris.
« Reply #33 on: 19 September 2012, 18:03 »
I've recently collected all this bits for this conversion. Reckon I've spent about £300-£350 in total in collecting everything needed. Doing the engine loom and sensor takes about 2 hours to swap and the throttle pedal conversion another 2 hours.
Well worth it if you can map the car yourself as the Me7.5 is far easier at mapping than the Me3.8.
If going to R-tech/B5 or the likes then no point in changing over as they can map the thing just as well regardless of Me3 or Me7
List of things needed for the conversion
ECU 06a906032hn or Hj are ideal
Loom from same car, both parts, drivers and passenger side
Coil packs
Knock sensors
Throttle body
Throttle pedal and harness
Camcover sensor
Map pipe and sensor
Maf and sensor
Lambda sensor
Thats pretty cheap.  Used parts I guess?
Click For Build Thread
Offline Prawny
  • R-tech power!!!
« Reply #34 on: 19 September 2012, 18:56 »
Nope, no TT injectors for you on an AGU.
Offline optispart
« Reply #35 on: 19 September 2012, 19:13 »
ok cool. will the saab injectors fit the inlet ok or is there anything i need to do?
Offline Prawny
  • R-tech power!!!
« Reply #36 on: 19 September 2012, 19:42 »
saab reds will go straight into an AGU inlet and work perfectly with the ECU when mapped to suit too.
TT 380's don't run so well on the ME3.8 ECU's. they can be made to work, but idle and off boost fuelling will never be right.
Offline ReDBull
« Reply #37 on: 19 September 2012, 20:49 »
So my inlet manifold I's the wrong way around but my turbos ok? I've fitted my Wellycooler over the weekend and I'm well impressed! I'm thinking turbo back system then a visit to Niki.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline optispart
« Reply #38 on: 21 September 2012, 04:03 »
brilliant thanks for the advice
