Author Topic: Limp mode virgin/Turbo blown  (Read 5541 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Limp mode virgin/Turbo blown
« Reply #10 on: 16 September 2012, 11:34 »
Just vagcomed, error code 17965 which is sticky VNT right...Strange how it has just happened now. I don't drive it like an old lady. Could it just have that problem when cold, or does heat not affect it? Could a fault N75 cause this issue?
I am going to check all the pipes now and possibly try a different N75...I do not have the time to clean the turbo today but maybe a job for the weekend!
Offline scarr89
« Reply #11 on: 16 September 2012, 12:15 »
One of the lower IC pipes was slightly popped off, now back on all nice and tight. Have checked the actuator and it doesn't seem to be sticking... :undecided:
Offline DCmk3
« Reply #12 on: 16 September 2012, 15:11 »
The boost leak was possibly causing the sticky VNT surely?
2014 Mk7 GTI - Littco L500
Offline scarr89
« Reply #13 on: 16 September 2012, 15:27 »
I don't get why it would though  :undecided:
I checked all the pipes, all the vacuum lines etc, all seemed fine. No leaks coming from any joins/blown gaskets etc and when shutting down it shut down straight away, no hissing noise.
Took it for a test drive and it seemed to drive well, I have it maybe 3/4 throttle up hill in 3rd, so plenty of opportunity to hit limp mode if it wanted to...Will keep an eye on it and will invest in some innotec turbo clean.  :lipsrsealed:
Offline Rhyso
« Reply #14 on: 16 September 2012, 15:29 »
Id be replacing the pipe. Chances are the lugs are worn and will pop out again sometime soon....
Offline scarr89
« Reply #15 on: 16 September 2012, 15:32 »
I checked it out, and they seem fine, just 126k worth of wiggling itself loose a touch. I need to have a proper look at my IC in general though, seems to be quite a lot of crud at one end of the IC joins  :undecided:
Offline Rhyso
« Reply #16 on: 17 September 2012, 11:38 »
They shouldn't move really though  :huh:  At that age I'd expect the lugs to be worn  :sad:
Offline scarr89
« Reply #17 on: 17 September 2012, 16:58 »
I'll get it on the ramp this weekend and see if it has moved at all  :undecided:
I managed to sort the problem, but I didn't really do anything, apart from clip that pipe back in place. She drove flawlessly on my 200mile trip yesterday, hit over 55mpg and was boosting fine. I think I may remove the turbo and strip it down and clean it out...What you reckon?  :lipsrsealed:
Offline Rhyso
« Reply #18 on: 17 September 2012, 16:59 »
If it ain't broke, don't fix it  :lipsrsealed:  :laugh: :laugh:
Offline scarr89
« Reply #19 on: 17 September 2012, 17:14 »
I like that...If it happens again then I'll take some drastic action perhaps!
