Author Topic: 18" or 19"  (Read 2894 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 18" or 19"
« Reply #10 on: 14 September 2012, 15:26 »
The trick is to find a set of wheels that "look" bigger than they are
LakerLover
Re: 18" or 19"
« Reply #11 on: 14 September 2012, 21:30 »
True... BBS LM'Rs 17inch look smaller that what they are!
Re: 18" or 19"
« Reply #12 on: 14 September 2012, 21:46 »
17"s for handling and comfort, 18"s are better for looks but in real terms are the biggest you would want to fit.
Offline mk3tony
Re: 18" or 19"
« Reply #13 on: 14 September 2012, 23:26 »
19's. nothing smaller.
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline mar_k
Re: 18" or 19"
« Reply #14 on: 15 September 2012, 21:27 »
Sad truth is, if you're not going to lower it, it'll look like a tractor on 18's or 19's!
If you want it to handle well 17's are the future....
handle well and golf shouldn't be in the same sentence lol.
To be fair handling seems to be the last thing on the mind of a lot of VAG owners,
Go as low as is stupidly possible ( even if you have to remove the arb and notch the chassis ) and fit the biggest wheels you can, Both do hideous things to handling
Offline Prawny
  • R-tech power!!!
Re: 18" or 19"
« Reply #15 on: 15 September 2012, 23:09 »
Yup, you end up with a car that looks like a hatch back with silly wheels to the general public, and to those with a proper car, it looks like a lowered hatch back with silly wheels.
Doesn't float my boat. I owned a 230bhp A3 with big spaced wheels and stretched tyres, and whilst I loved it to bits, you couldn't really use it all that well.
Offline shaft69
Re: 18" or 19"
« Reply #16 on: 16 September 2012, 10:50 »
Mine on 18" LM'R's wouldn't go any bigger, especially if only standard brakes look crapp
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline xtetx
Re: 18" or 19"
« Reply #17 on: 18 September 2012, 12:51 »
