Author Topic: Gloss black nose and bum  (Read 5640 times)
Offline Hurdy
Re: Gloss black nose and bum
« Reply #20 on: 19 September 2012, 12:36 »
like that Hurdy just need to gloss out the Rs for the stealth look, toying with this on mine but cant make me mind up
You can always try it and if you don't like it sell them on. :cool:
Seat Leon Cupra Black 290 DSG
Offline wigit
« Reply #21 on: 19 September 2012, 23:23 »
probably worth a punt but need to sort out some other tweaks and maybe scratch an itch for a new daily :)
Offline Jimble
« Reply #22 on: 22 September 2012, 22:09 »
Does the grill need to come off to change the front one? i''ve been reading that it can be twisted off while the grill is still on. ???
Offline Hurdy
« Reply #23 on: 22 September 2012, 22:20 »
You can risk it, but most people tend to break the holding clips. Much safer to remove the grille first. :smiley:
Offline TurboTrev
« Reply #24 on: 23 September 2012, 09:42 »
Regarding an R (and maybe other models) it also depends how new the car is.  My 2012 R had the taps melted flat so once you have the grill off you have to get some snipe nosed pliers and break up the melted area.  The VW badge can then be taken out of the grill but it's knackered and can't be reused.  There is a guide here: http://www.vwgolf.net.au/showthread.php?3085-DIY-Replace-the-Front-VW-emblem-of-Mk-6-Golf-R
Offline Hurdy
« Reply #25 on: 23 September 2012, 18:35 »
Yes, I think if that is the case you can Dremel the excess off and use hot glue to fix the replacement in. If you want to refit the original you can uses hot melt again.  :cool:
