Author Topic: mk3 golf 16v correct wheel offset  (Read 5601 times)
Offline whitemk316vgti
Offline tweed
Re: mk3 golf 16v correct wheel offset
« Reply #11 on: 13 September 2012, 12:34 »
You really need to ring them and ask.
Phone Rimstyle they are good with spacers that you need for the rim you want
Offline wakeskater
  • H20 PHW MK3 16V DAILY ,,,MK1 16V PROJECT,,
« Reply #12 on: 13 September 2012, 13:45 »
iv got 15s x7 with an offset of 20 with 195 50s  and   i had to do the lip on rears down 50mil maybe on back
Offline tweed
« Reply #14 on: 22 September 2012, 12:06 »
Need spacers
Offline berry9112
« Reply #15 on: 22 September 2012, 13:22 »
In short, yes of course they will fit if you get the right stud pattern. mine are et38 and clear the caliper by about 4-5mm. Get them at et30 put them on then measure the top of the tyre to the edge of the arch, get your spacers. Lower ET you will need to roll the inside arch lip and have stretched tyres so it doesn't go through your side wall.
Offline tweed
« Reply #16 on: 22 September 2012, 13:43 »
He needs spacers to clear the front calipers.
And you can only needier what spacer you need if you have new pads.
I'll say it again, ring rimstyle!
