Author Topic: Speedo help.  (Read 3231 times)
Offline stainesy
Speedo help.
« on: 12 September 2012, 14:21 »
Ok when I bought my 1985 jetta a few weeks back it came with a speedo on the boot as the one in it makes a ticking sound where you can hear the speedo cable spinning and the need is jumpy but it does tell you your speed. Was told the speedo in the boot was a decent one he hadn't got round to fitting.
Fitted it today and it's buggered by the looks of it as the needle does not sit at 0 and when I reverse rhe needle goes backwards and when I drive it don't go up.
So had to put the old noisy juddery ones back in.
What I want to no is. Do all mk2 golf speedos fit or does it have to be one from a cl model or something?
As I'm looking for a new one.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Speedo help.
« Reply #1 on: 12 September 2012, 14:31 »
Sounds like the speedo needle has dropped below the stop needle... Whip the speedo out (6 screws) and move it above the pin...
http://www.golfgtiforum.co.uk/index.php?topic=143227.0
For More Info Click To See;
Offline stainesy
Re: Speedo help.
« Reply #2 on: 12 September 2012, 15:11 »
Oh yeah it has  :rolleyes:  :grin:
Ok sorted it just got swap them back over now and see if it's worked.
Iv noticed the clock don't work in this one ither so hopefully may be a fuse.
Does the clock have a fuse of its own?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Speedo help.
« Reply #3 on: 12 September 2012, 15:33 »
not sure on Fuse - Check the Fusebox FAQ in the tech section...
Also check all the 3 earth's on the car are in good condition & connected.. My Mrs GTI had issues and was resolved with a new bonnet earth..
Offline stainesy
Re: Speedo help.
« Reply #4 on: 12 September 2012, 16:20 »
Ok now fitted the new speedo. And all is ok apart from it is still flickering. The speedo needle tells the correct speed but is flickering up and down all the time. Does it loads at low speed. The faster I go the less it flickers. WTF?
Offline dubber36
Re: Speedo help.
« Reply #5 on: 12 September 2012, 16:33 »
The one on my old 8V used to do that, untill a week before I sold it, when it fixed itself.
I think the problem is caused by a worn drive gear on the gearbox end of the cable.
Offline stainesy
Re: Speedo help.
« Reply #6 on: 12 September 2012, 17:27 »
So would a new cable fix it or is it gona be something inside the gearbox needs sorting pain in the arss?
Offline CanisLupus
Re: Speedo help.
« Reply #7 on: 12 September 2012, 19:11 »
Like to also know if this may be the worm gear breaking down or the clocks.
My Jetta has been doing the same too for the last year or so. At low speed very light flickering. Between 25-35 mile it flickers quite a bit, but after 40 it doesn't flicker at all. Also I always have a tick tick tick sound from behind the clocks.
Had swapped the Speedo cable few months back, that didn't sort the issue. The worm gear looked good, so didn't swap it at the time. So it could be worm gear or clocks.
Might buy a worm gear off the bay to try, only cost a few pounds and is swapped in 5 minutes.
Offline stainesy
Re: Speedo help.
« Reply #8 on: 12 September 2012, 19:52 »
What is warm gear and how do I change it?
Offline CanisLupus
Re: Speedo help.
« Reply #9 on: 12 September 2012, 21:32 »
Worm, not warm :) Worm gear, or drive... it's the plastic "gear" on the end of the speedo cable which goes into the gearbox.
http://www.ebay.co.uk/itm/VW-GOLF-JETTA-MK1-MK2-GTI-SPEEDO-DRIVE-C36-/190388506642?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c540a1012
There 2 (or more?) varients, one was for GTi's and the other for the rest I think. You can use either, but your speedo will not show correct speed, as one has more teeth than the other.
