Author Topic: Where does this go?  (Read 1529 times)
Offline rfn_hodgson
Where does this go?
« on: 11 September 2012, 21:44 »
Hey fellas were does this pipe go ( the one on the far right) cheers muckas
http://www.ebay.co.uk/itm/300775987043?redirect=mobile
« Last Edit: 12 September 2012, 16:03 by rfn_hodgson »
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Steve_PD
Re: Where does this go?
« Reply #1 on: 11 September 2012, 23:23 »
Helps if you post the picture link :tongue: :rolleyes: :grin:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 12 September 2012, 09:06 »
Hold on...Let me just use the force to try and work it out!!!  :tongue:
Offline harlemex
« Reply #3 on: 12 September 2012, 14:11 »
It goes under the battery tray the across to the head where it clips in on the empty clip. Then feed it under the TIP and into the baulkhead via the air conditioning inlet.
Offline GTi_James
« Reply #4 on: 12 September 2012, 14:30 »
...am i missing something?  :huh:
Offline rfn_hodgson
« Reply #5 on: 12 September 2012, 16:03 »
Offline GTi_James
« Reply #6 on: 12 September 2012, 17:49 »
far left looks like its to the SMIC from the TB, the two in the middle look like something for the TIP? not sure though and would be appreciated if i were corrected (learning curve) and the one on the end i've seen before but cant tell where it goes, could probably point and say there if you want me to though  :laugh:
Offline cullygti
« Reply #7 on: 12 September 2012, 20:53 »
one on the far right goes from smic to pancake pipe
Offline james2
  • No scammers please.
« Reply #8 on: 12 September 2012, 22:17 »
You put it in the post and send it to me.  :wink:  :grin:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline rfn_hodgson
« Reply #9 on: 13 September 2012, 10:44 »
cheers  buddy
