Author Topic: 16V ABF Cold idle problem  (Read 8623 times)
Offline technics100
Re: 16V ABF Cold idle problem
« Reply #10 on: 22 September 2012, 21:28 »
I got full VCDS today and scanned the car this evening, getting error code
00519 - Intake Manifold Pressure Sensor (G71)
            03-10 - No Signal - Intermittent
Does that indicate the vac line to the ECU?
1995 Twilight Voilet Mk3 GTi 16V 5 door
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 23 September 2012, 12:48 »
As said replace your vac lines especially the one from back of the intake manifold through the scuttle to the ecu,then clear codes.
Offline Metallix
« Reply #12 on: 24 September 2012, 15:43 »
Open the ECU up,  there is an internal pipe as the sensor is further inwards.   This pipe may be blocked or perished.
^ see the hose at the bottom of the picture?
Offline technics100
« Reply #13 on: 24 September 2012, 16:37 »
I have 3M of pipe ordered, will take the ECU out and have a hoke at it.. Will also try and check with vag-com
Offline technics100
« Reply #14 on: 29 September 2012, 23:17 »
Replaced the main vac line to the ECU, also did a few other lines with the 3mm hose.  Also cleaned the throttle body, ISV and adjusted the accelerator cable.. Hasn't done it since.. fingers crossed thats it sorted.. Now to sort that airbox..
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 29 September 2012, 23:33 »
Lets hope thats it  :smiley:
