Author Topic: Steering column help please  (Read 2671 times)
Offline monzablue16v
Re: Steering column help please
« Reply #10 on: 08 July 2005, 00:06 »
Hi
I live near a real good VW scrapper (floods of PM's!) in Huddersfield Yorkshire so if you need a new column or can't track any parts down let me know and i can get it and post it to you. All part o' the service!
Offline strega
« Reply #11 on: 08 July 2005, 12:50 »
Hi Mate, thats the best news Ive had all week, I will e-mail you off site about the cars needs and we'll take it from there, I live fairly close to you in Wilmslow so could actually come and collect.Speak to you soon mate  :smiley:
Offline GTI EDITION (aka LTD)
« Reply #12 on: 08 July 2005, 13:03 »
Probably the top bearing knackered which is integral to the alloy steering lock assembly(fairly easy job to do) :wink:
« Last Edit: 08 July 2005, 15:04 by VENTO GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline strega
« Reply #13 on: 08 July 2005, 14:03 »
Ok, that sounds better, If I get a new steering column that should sort it right? I hope theyre easy to fit............. :smiley:
« Reply #14 on: 08 July 2005, 15:10 »
I've just had a thought and,I know it may sound daft (and probably isn't the case )....but does the steering feel rough or does it just sound rough as it might just be the horn slip ring that is worn as they can make a horrid graunchy noise ?? :huh:
Offline strega
« Reply #15 on: 08 July 2005, 15:23 »
It really is an odd thing, it feels a little rough but I mean a tiny bit, there are noises when I turn the wheel but im really not sure if thats just causes by the stoney road its parked on and the fact that its gona be a little rough when turning the wheel whilst not mooving, could it in fact be the steering rack and not the column?Im very confused sorry mate  :cry:
diagnosis-dub
« Reply #16 on: 08 July 2005, 15:54 »
"Roughness in steering coloumn" sounds a bit vague and doesn't give a lot of clues as to what is up. The only way you'll get roughness is that either or both of the top or bottom coloumn bearings have gone. I would be inclined to put the front up on stands so you can turn the steering lock to lock and feel for play and roughness as you do so.
Also if the bolt were loose then in theory you should have an "excessive play in coloumn top bearing" fail on your sheet which you haven't, its easy enough to check , remove the two screws that hold the lower shroud on and feeling to the left of the coloumn and up under the dash you'll find an allen key bolt, this is what holds the lock housing to the lower coloumn, rock the wheel and if the bolt is loose the lock section will move slightly, try doing up the bolt to make sure its tight.
The horn ring being noisy wont matter as its not a fail point, if the top bearing, which is part of the lock housing, has gone then you should be able to tell by holding the steering wheel top and bottom and moving your hands back and forth, roughness would indicate a bearing going so in theory you should also have play in it.
The good thing is that your car is a '85 model, these dont have the steering wheel spacer and makes removing the lock housing a darn sight easier. The bearing in the lock housing on mine was well worn and got an advisory on the MOT, luckily I managed to get a brand new one of ebay for next to nothing, VW quoted me £20.17 + VAT for a new one. I looked on my ETKA  and its the same part for your car.
part number is 155 905 851
Offline strega
« Reply #17 on: 08 July 2005, 17:01 »
Thanks very much for your help, you really know your stuff sir,I will investigate further and report back, thank you again, top marks peeps  :smiley:
