Author Topic: GOLF MK3 GL ESTATE TO 20 VALVE TURBO :-)  (Read 58828 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: GOLF MK3 GL ESTATE TO 20 VALVE TURBO :-)
« Reply #20 on: 07 September 2012, 12:15 »
Caddy was finished yonks ago, I refined the Intercooler pipe work route before we finishe it
The owner then ripped out the engine so he could paint the bay back original shell Colour (always changing his mind on colors)  :rolleyes:and asked me to wire it back up which I did
It's now in a bodyshop having other work done and should be on the road property after that
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline SoundillusioN
« Reply #21 on: 07 September 2012, 12:42 »
Yeah I lost touch with the thread, is it up to date, might have a look if it's still on here?
Offline DanChave
« Reply #22 on: 07 September 2012, 17:43 »
I would be interested in having a look at the caddy as well!
Offline F17BAD
« Reply #23 on: 09 September 2012, 21:39 »
few more bits done
picked up a tiny amount of the new bits i have on order for the build, including the ultrasonically cleaned injectors
Removed old rods.. here you can see them installed
Here you can see Number 4 Conrod removed
ARP Con rod Bolts are a must as this is the most stressed bolt in the entire engine of a car
On this install, ZRP Con rods from TSR were chosen
Forgot to get a picture of them installed  from underneath but ill do this tomorrow
Started to build engine back up
Offline CCGTI
  • Fueled Society
« Reply #24 on: 13 September 2012, 10:14 »
that will be awesome when done
Offline DanChave
« Reply #25 on: 13 September 2012, 11:57 »
Looking great bud :)
Offline mark-mk3gti
« Reply #26 on: 14 September 2012, 23:29 »
Any more progress to report :) :)
Offline F17BAD
« Reply #27 on: 14 September 2012, 23:37 »
will be more updates in the week, currently cleaning gearbox and making that fresh... not a easy feat on this dirty affair
engine now rebuilt,
hope to have this completed by next weekend
Offline VonGrun
  • BOoM
« Reply #28 on: 16 September 2012, 09:40 »
Will be helping as much as I can next week... Can't wait to get this car on the road!
Offline F17BAD
« Reply #29 on: 18 September 2012, 23:32 »
made a bit more progress tonight
gearbox is now fully prepared and half in paint, as are some other bits..
ill get pictures of these tomorrow
Got cam belt and new tensioners fitted today
and got most the pipework and flanges back onot the engine too.. its basically ready to be installed now
just need to fit the sump which has had my trade mark treatment
TO;
Con rods fitted picture from underside, also fitted new oil pick up pipe and cleaned out the Oil pump
Here is the Gearbox iv had to clean, she is now half in ;aint (underside finished just top side to do)
You can see what iv had to deal with
you will see the results soon...  Full satin black on this one
oh, also did the Aux belt tensioner full satin Black too and the Starter motor, will get some pictures of these parts tomorrow also.. was late when we finished up
till next time folks  :cool:
« Last Edit: 18 September 2012, 23:35 by F17BAD »
