Author Topic: what rep r32 mesh have you used? " fitted wih pic"  (Read 3907 times)
Offline rio_gti
Re: what rep r32 mesh have you used? " fitted wih pic"
« Reply #20 on: 13 September 2012, 08:12 »
Cheers cully!!!
It's not properly fitted I cut and tried befor spraying the bumper but u used the existing fixings (screws and washers) as there a moulded fixin points in the bumper  :wink:
Will prob fix it with screws then use a few dabs of tiger seal to be safe
Offline mk3tony
« Reply #21 on: 13 September 2012, 09:08 »
I would be well happy with that! Have you got a picture of behind to see how it sits and how you'll secure it?
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline rio_gti
« Reply #22 on: 13 September 2012, 10:40 »
i havent mate soz  :embarrassed: will get one once its ready to go on as i have removed it all now readt to take down to the sprayers on sat  :cool:
Offline james2
  • No scammers please.
« Reply #23 on: 14 September 2012, 20:17 »
take a look at mine to compare if it will look like the oem grill...... il get measurements of the small honeycombe holes tomorrow for you  :wink:
That looks good.Is your bumper one of the cheap abs ones. I have one but still have the cheap
Here is the mesh fitted (the one from the link) against a gen mesh (cheers my trusted friend  :grin: ) its a touch wider but opinions please!!!!
That looks good.Is your bumper one of the cheap abs ones. I have one but still have the cheap metal mesh
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline rio_gti
« Reply #24 on: 14 September 2012, 21:03 »
Yeah it is!!!! I didn't wanna put it on with the metal mesh it's been sat in the spare room for over a month!!! That mesh in the link is pretty good quality tbh!!
