Author Topic: creation motorsport picture help please  (Read 8859 times)
Offline cooki
  • 1.8T AUM
Re: creation motorsport picture help please
« Reply #10 on: 03 September 2012, 21:25 »
Creation have just got back to me and said that my pipe in question is a moulded pipe that replaces the T piece.
But on consulting an old thread isnt the PCV valve inside the T piece??so in theory i would be removing/by passing tbe pcv valve?
Does this sound right to anybody?
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline cullygti
« Reply #11 on: 03 September 2012, 22:09 »
it would appear it does bypass it mate as there wont be anywhere for the pcv to fit as for replacing item 5 is there another pipe in with the kit as that will only replace part number 2
Offline cooki
  • 1.8T AUM
« Reply #12 on: 03 September 2012, 22:31 »
No other pipe suplied mate so think they have got the wrong idea about this replacing pipe 5 also lol.i only realy need it to replace pipe no2 but im unsure again now as i dont no about bypassing the pcv valve??
Offline GTi_James
« Reply #13 on: 03 September 2012, 22:56 »
if you want i'll be having my forge 'Y' pipe off and the 'S' pipe for the lower crank case breather, only done about 300miles, yours for £20 lol had to put it back on due to my catch can being faulty  :lipsrsealed:
Offline cooki
  • 1.8T AUM
« Reply #14 on: 03 September 2012, 23:11 »
Pm'd u buddy.
What pipe numbers are they please from the diagram on the 1st page i put up??
Obviously the Y pipe is no5 lol.
Offline GTi_James
« Reply #15 on: 03 September 2012, 23:34 »
pm'd mate, and it has the part replacement numbers on them  :wink:
not bad seeing that i paid alot for them but they made me happy until i tore some of my other pipes and going down the catch can scene
Offline GTi_James
« Reply #16 on: 03 September 2012, 23:50 »
I believe they're numbers 5 and 2 I think. It's the upper and lower breather pipes
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #17 on: 04 September 2012, 08:48 »
I had this pipe on mine, until I ended up fitting a catch can. The pipe you have bought, is a replacement for 11 and 2 only, the metal tube goes in the end that connects to pipe 5, which you will have to purchase separately. I actually have one for sale, a black one if that is any good?
+ the pcv valve still goes in the end on the T piece of the pipe you have, but not in the bit that goes to the sump. if you see what I mean
« Last Edit: 04 September 2012, 08:52 by oceanic-green »
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline cooki
  • 1.8T AUM
« Reply #18 on: 06 September 2012, 11:14 »
Thanks for the help guys but still not 100% on this.i have the metal connector to connect to pipe no5 so thsts fine. But at the other end do i replace the t-piece with my new pipe then conect pipe no1 and funny valve no8 in to my new pipe??
