Author Topic: Is it safe to cut wheel bolts down abit?  (Read 3822 times)
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: Is it safe to cut wheel bolts down abit?
« Reply #10 on: 03 September 2012, 09:34 »
Which is why you should never sharpen chisels etc with a grinder
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #11 on: 03 September 2012, 21:13 »
cut mine down with a grinder. use a slitter disc.will be fine
No it won't  :laugh:
Bolts have a certain strength for a reason. Using a cutting disc will put so much heat in the bolt it will take the strength away.
I won't explain how metal works and how it forms to create strength, because you proberly wouldn't understand.
Ohhhhh, some one feeling grumpy?   :wink: :grin:
 :kiss:
Offline spikenipple
« Reply #12 on: 03 September 2012, 21:21 »
Cutting bolts down with a cutting disc or a grinder is fine as long as you cool them properly. Machine tool cutting coolant is best, but plenty of WD40 will do the job, eg. drown it in fluid, cut a bit, drown it in fluid, cut again etc.
VW BUSH
« Reply #13 on: 04 September 2012, 17:00 »
This will change the property of the bolt if you get it too hot in between cooling it off, not that I am splitting hairs :grin:
Online jv
  • Administrator
« Reply #14 on: 04 September 2012, 17:15 »
Buy new bolts  :grin:
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #15 on: 04 September 2012, 18:17 »
5mm spacers?
Offline Dolly
« Reply #16 on: 04 September 2012, 21:46 »
read my mind  :grin:
