Author Topic: Calling all you electrical boffins!  (Read 2199 times)
Judderi
Re: Calling all you electrical boffins!
« Reply #10 on: 06 July 2005, 12:39 »
Ah i get what your saying now. I had no idea the main bulbs were lit a little when just on sidelights. I think your right also about other affected wires. Because if this wire was the only faulty one surely i would just have a problem with my lights. There were 3 or 4 blown fuses which i have replaced but still have no joy. I think i may have lost power to part of the fuseboard. One other question. Just before the burnt out wire connects to the fuseboard it splits into 2 and the other half goes to a plug consisting of 3 wires on top of the steering columb. any ideas what this bit on the steering columb does?
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
« Reply #11 on: 06 July 2005, 12:48 »
It's most likley to be the connector for the switch, delivering full voltage to the headlights or full voltage to the resistor, where it is stepped down to about 6-8V, as the lights are now controlled from relays on the original loom and  I wouldn't worry too much about those wires.  Hope this helps ya!
WARNING DRUMMER ON THE LOOSE :evil:
Offline tobz.
« Reply #12 on: 06 July 2005, 13:26 »
Oops looks like I was completely wrong about that resistor, all these years I've believed it to be something to do with the heater. Ah well you learn something everyday.
You got any pics of your dad's split ?
Judderi
« Reply #13 on: 06 July 2005, 13:27 »
Cheers anyway.
