Author Topic: Some problems with MK4 GTI 180 '03' Please help somebody  (Read 3576 times)
Offline Jayy
Re: Some problems with MK4 GTI 180 '03' Please help somebody
« Reply #10 on: 02 September 2012, 15:58 »
Thats an idea, will try that tomorrow, i can never get the airbag off, so ill have to get someone to do that, did a proper search to find:-
01330 - Central control module for central convenience (J393)
Supply voltage to low - Intermittent
01135 - Interior motioring sensors
Open curcuit
00928 - Locking module for central locking - front drivers side (F220)
Implausible signal - intermittent
00929 - Locking module for central locking - front passenger side (F221)
00930 - Locking module for central locking - rear left side (F222)
00931 - Locking module for central locking - rear right side (F223)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 02 September 2012, 16:40 »
TBH that sounds like your CCM is goosed
Offline Jayy
« Reply #12 on: 02 September 2012, 16:46 »
id pay for it to be that, instead of all the non sense with the doors
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 02 September 2012, 17:15 »
Yours will be the 1C0 CCM, they are around £50 second hand on ebay. I dread to think how much a new one is
Offline Jayy
« Reply #14 on: 02 September 2012, 18:39 »
will any letter at the end be ok?
Also where abouts does it go? looks abit big for behind the steering wheel?
thanks alot of your help mate, really appreciated!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 02 September 2012, 20:05 »
It's not that big, probably A5 size. You need to replace yours with the exact same number. You can find out the part number via VAG COM
Offline Jayy
« Reply #16 on: 02 September 2012, 20:17 »
In section 46 on vag com? So it does go behind the wheel?
Nice one
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 02 September 2012, 20:29 »
not behind the steering wheel, just to the right of it behind the dash panel
Yeah 46 IIRC
Offline Jayy
« Reply #18 on: 02 September 2012, 21:18 »
right, unplugged the module, everything opens expect the front passenger door, this is still deadlocked.
Disconnected battery, still don't open..
Soon as the modules plugged in, the rear drivers packs up straight away..
Offline Jayy
« Reply #19 on: 02 September 2012, 21:48 »
Update **** booted the door a good few times from the inside, and the passenger door has started to work, well all of them to be honest, 1 in 5 times the passenger door won't open..
Now would you advise this is a CCM issue, or door module? weird or what :S
