Author Topic: Name that tune?  (Read 4355 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Name that tune?
« Reply #10 on: 28 August 2012, 19:38 »
Well what should have been a simple enough task turned into an absolute ballache, on attempting to change the oil and filter the sump plug decided otherwise and sheared off which now means a new sump pan is required before I can progress with anything else.  :angry:
Offline tweed
Re: Name that tune?
« Reply #11 on: 28 August 2012, 19:48 »
They don't need to be that tight  :lipsrsealed:
Re: Name that tune?
« Reply #12 on: 28 August 2012, 20:27 »
I know, f**k knows why it was so tight as i had it out last year and i remember only pinching it up although it was never in good condition from when i got it from the previous owner so it's my own fault for not replacing it last time. I even tried whacking an Irwin bolt extractor on the remaining stub but all that did was fracture the alloy pan around it - meh!  :undecided:
That aside, I'm starting to think it might be the cam chains - How big a job is it to replace these?
Re: Name that tune?
« Reply #13 on: 28 August 2012, 20:47 »
The cam chain is easy enough to replace.
Offline Screech16v
  • MK3 20vt AGU
Re: Name that tune?
« Reply #14 on: 28 August 2012, 20:53 »
I dont think you should tackle cam chain if you cant undo a sump plug   :lipsrsealed:
 :grin: :grin:
Offline tweed
Re: Name that tune?
« Reply #15 on: 28 August 2012, 21:04 »
 :grin: :grin: :grin: :grin:
Pretend the cam is worn and you need to upgrade
Re: Name that tune?
« Reply #16 on: 28 August 2012, 21:11 »
Cheeky f**k*r!  :grin:
Actually now I've thought about it more i doubt the main noisy culprit is the cam chain as they're on the passenger side of the head and the noise is more prominent from the cambelt / driver end...hmm, maybe i had a sh!te tensioner last time then?  :undecided:
Re: Name that tune?
« Reply #17 on: 28 August 2012, 21:12 »
In an ideal world maybe but funds are seriously tight at the moment and im more concerned at stopping the b@stard from going bang right now.
Re: Name that tune?
« Reply #19 on: 28 August 2012, 21:30 »
I think the only thing that oil treatment doesn't supposedly do is make the friggin tea!
