Golf mk3
hardmonkeys
Engine Diagnostic Check??
Topic: Engine Diagnostic Check?? (Read 2548 times)
CJA321
Re: Engine Diagnostic Check??
Reply #10 on:
26 August 2012, 16:15 »
Could be afew things. Check your brake fluid level thats first thing. Could have a leak somwere. Could be handbrake switch could even be wiring for brake fluid sensor.
Most likely fluid related, dont think theres diagnostic codes for that thou
MK3 GTI 20vt project
http://www.golfgtiforum.co.uk/index.php?topic=230628.0
Foreveryoungaus16v
Reply #11 on:
26 August 2012, 16:23 »
The only thing out of that which i hav not done is check the wiring. Break fluid and switch are fine. Is it not a common fault for the mk3?
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
Screech16v
MK3 20vt AGU
Reply #12 on:
26 August 2012, 16:43 »
Hand brake light can be a sign for a duff abs ecu,does your abs light on the right come on ,selfcheck then go off all ok?
Foreveryoungaus16v
Reply #13 on:
26 August 2012, 16:46 »
Yeah mate abs light is fine
Screech16v
MK3 20vt AGU
Reply #14 on:
26 August 2012, 16:51 »
Could be a dodgey fluid cap then ,is the light just on all the time except while ignition is off of course
Foreveryoungaus16v
Reply #15 on:
26 August 2012, 16:57 »
Yeah it is
Screech16v
MK3 20vt AGU
Reply #16 on:
26 August 2012, 17:19 »
try unplugging the cap
Foreveryoungaus16v
Reply #17 on:
26 August 2012, 17:54 »
Unpugging the break fluid cap hey?
Foreveryoungaus16v
Reply #18 on:
26 August 2012, 18:06 »
Jst done it its not that.
twotwofour
GTI forum regular
Reply #19 on:
27 August 2012, 13:38 »
If you have a laptop you can buy a diagnostic kit to work with it. Makes life a lot simpler
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Golf mk3
hardmonkeys
