Author Topic: over from the mk3 section. new car few questions  (Read 3700 times)
Offline stainesy
Re: over from the mk3 section. new car few questions
« Reply #10 on: 22 August 2012, 21:07 »
ok been driving it around alot today and it is great fun and im getting looks and the thumbs up from loads of people and nearly every vw driver i pass has a huge look as they drive past lol.
car runs like a dream. does seem to use quite abit of fuel tho for a 1.6 carb. uses the same as my 2.0 mk3 gti did.  :undecided:
Offline mush
« Reply #11 on: 23 August 2012, 21:00 »
I saw an orange one of these just the other day, I really like them they look nice lowered as well. if it wasn't for affording funding my mk2 vr6 I'd look at getting one. Will hold its value as well. Nice purchase.
MK2 golf 16v :-)
Offline stainesy
« Reply #12 on: 23 August 2012, 21:30 »
yeah i am loving the look of it. at the moment trying to sell my set of porsche teledials staggered with 5x100 adaptors so i can buy some banded steels for it or would like to swap for some.
took a couple of pics of it.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 23 August 2012, 23:56 »
want to upgrade the brakes as they are cack. can i fit gti brakes and what do i need to do this. just the fronts really
You can either replace the non-vented fronts for 239mm front vented, or replace the hubs for 16V hubs and 256mm brakes, as well as replacing the master cylinder for a 22mm one.
The second option is much better.
Either way, replace the brake fluid first and see if that improves things.  Don't be tempted by grooved and drilled discs.  That is a fool's errand.
just found this on ebay.
http://www.ebay.co.uk/itm/VW-Golf-256-mm-brake-upgrade-MK1-MK2-GTI-caddy-/251132225501?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a78a5a7dd#ht_500wt_1288
do i have to use a 22mm master cylinder for this? what car is the 22mm master cylinder from? may be easyer to search by car.
NO YOU NEED THE HUBS for this conversion...
These won't fit your car, Without the hubs they are useless....
As DH said try doing the Fluid with a full bleed off 1st...
Did this with my Lads Driver with 239mm fronts and drum rears and what a difference it made..
For More Info Click To See;
Offline Cory
« Reply #14 on: 25 August 2012, 19:50 »
new pads and a bleed was well worth doing to mine. made a noticable difference.
mines running a webber and my fuel bill is very expensive. think its just the nature of the beast.
enjoy it! looks  :cool:
Offline antogoof
  • bbm mk2 g60
« Reply #15 on: 28 August 2012, 21:21 »
nice motor dude, what miles are on it? :smiley:
mk2 bright blue met bits wanted in north west.
Offline stainesy
« Reply #16 on: 28 August 2012, 21:36 »
Cheers mate
109000 mate.
