Author Topic: Mk3 Wagon On 9's ;) ;)  (Read 42688 times)
Offline RattyGTi
Re: Mk3 Wagon On 9's ;) ;)
« Reply #30 on: 20 December 2012, 19:08 »
i always thought vento front ends were over done but it came up for the right price & i cudnt help myself but buy it so will be on after christmas sometime
Sell my Golf? I'd rather shove wasps up my arse!!
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #31 on: 21 December 2012, 21:02 »
Nice wagon mate had one myself a while back, the vento front end will look the nuts mate  :wink:
Golf Gti
Offline RattyGTi
« Reply #32 on: 09 January 2013, 11:36 »
not much of an update guy but the new back bumper is all ready for plastic welding the vento bonnet & grill are gettin started tonight & i shud have new front wings orederd in the next few days vento left front wing with no aerial hole & camber shim shud b ordered end of the month but im not sure if -1.5 will b enough to get my 9's in & go lower  :undecided: does any1 know it it will b enough??
Offline RattyGTi
« Reply #33 on: 16 January 2013, 22:05 »
dint change the bonet over as im still prepping it for paint but this gives a rough idea as to how the front end will look with the vento front end on
« Last Edit: 01 April 2013, 19:09 by RattyGTi »
Offline SoundillusioN
« Reply #34 on: 16 January 2013, 22:17 »
Gives an idea as to how a Vento would look after a minor front ender.  :kiss:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #35 on: 16 January 2013, 22:19 »
He's going for the crash victim look.
Offline tweed
« Reply #36 on: 17 January 2013, 21:11 »
What is the et on the 9's?
What tyres? And what arch work have you done?
Offline DanChave
« Reply #37 on: 18 January 2013, 08:30 »
It will look good man! Keep your eye out for an earlier grill though as they look much better :)
Offline RattyGTi
« Reply #38 on: 18 January 2013, 11:51 »
the 9's are et20 mate & not done any arch work there on with 11/12mm spacers on front cant remember which & 10mm spacer shims on the rear its not as low as it can go tho need camber for that but will be going lower & yea i thought that dan gonna see how it all looks when its finished & then mayb get a different grill
Offline tweed
« Reply #39 on: 18 January 2013, 17:06 »
Et20 with or without spacers? So without they would be et10 with them?
Camber is not enough!!! You need to roll the lip flat then push the arch out. Front will be a issue if you want to go really low. Put fall camber on the front too! Still might rub with pulled out arch.
Try getting smaller sidewall tyres. They give more room than narrow tyres.
Camber shims. Don't put the 20-20 at top. Have driver side at 18-18 and passenger side 22-22. Have numbers facing you when fitting on both sides.
If you want to go low then 17-17 and 23-23
