Author Topic: 1984 Mk2 5 door project (G60)  (Read 26199 times)
Offline ian_GTI
Re: 1984 Mk2 5 door project (G60)
« Reply #20 on: 06 November 2012, 17:58 »
A few bits turned up today
A mini spray gun & water trap to paint the engine and a few small parts
And a new 65mm pulley and charger blanking plate
Offline ian_GTI
« Reply #21 on: 13 November 2012, 18:29 »
Bit of a update:
Engine block and head has been stripped and cleaned (acid dip under pressure)
Block:
All oil and waterways cleaned
New piston rings & oil rings
New small end bearings
New crank bearings and balance
New big end shells
Head:
New valve guilds and seals
New springs
Valves re seated
Cam oil seals
I'm waiting on crank oil seals and a new crank pulley that will be drilled into the crank and dowel pins fitted to stop the stress on the keyway
Here's how it's looking
Offline ian_GTI
« Reply #22 on: 15 November 2012, 20:41 »
Painted the head and block today;
Just need to clean up the gasket faces and its ready to start going back together
Offline ian_GTI
« Reply #23 on: 25 November 2012, 12:18 »
Broke the car down to a shell yesterday massive thanks to Kev for the help
The differnce between a genuine wing and a pettan one
Gave it a jet wash ready for degreasing next week
