Author Topic: catch can pics please..  (Read 2472 times)
Offline wolfie1981
Re: catch can pics please..
« Reply #10 on: 17 August 2012, 22:03 »
see the catch cans on ebay can you just use the 15mm fittings that come with it???
or do you need to find 19mm fittings??
Offline wolfie1981
« Reply #11 on: 19 August 2012, 19:56 »
any help would be great
Offline jamie1989
« Reply #12 on: 20 August 2012, 09:17 »
I run that can, its fine to use.
Use 19mm everywhere then reducer to reduce pipe from 19mm to 15mm(I couldnt find 15mm so I used 16mm) to catch can.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline cooki
  • 1.8T AUM
« Reply #13 on: 21 August 2012, 12:31 »
I'm also looking in to fitting a catch can. Can somebody pop some links up for exactly what I will need to fit 1 to my AUM golf??
I've seen the eBay cans for around £25 with a 15mm inlet/outlet. So will I need a few metres of 19mm silicone pipe work then a few 19-16 reducers??
Any help apretiated.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 21 August 2012, 19:42 »
be careful as the cheap ones don't have any material inside to condense the oily vapour, this is why a lot of people don't have much to drain out
Offline cullygti
« Reply #15 on: 21 August 2012, 21:03 »
i always have lots to drain from mine tbh every couple of weeks..... dont know if its because of my 19mm fittings but cant see them making much of a difference over 15-16mm ones... and i dont have anything inside my can but have been thinking of trying to get summat in there as a filter  :smiley:
Offline GTi_James
Offline Dalo Harkin
« Reply #17 on: 22 August 2012, 09:15 »
didnt someone put a  wire wool in my catch can for it to condense the vapour  :undecided:
Offline GTi_James
« Reply #18 on: 22 August 2012, 09:22 »
i dont knw about wire wool, i think there should be a mesh of sorts, havent even opened mine up to see yet  :embarrassed:
