Author Topic: FAO VW or Bentley technicians  (Read 7020 times)
Offline dazzawest1987
« on: 15 August 2012, 11:24 »
hi all, im after a bit of advice. my boss has got a bentley continental GT, it's got a W12 twin turbo engine, which i know is the same the engine that VW put in the Phaeton so im hoping one of you may be able to help me. his engine management light is on snd come up with the fault code P2438, after a bit of googling ive found it seems to relate to a secondary air injection fault. there was a technical bulletin out about this but it has been carried out already. so if anyone could shed abit more light on this, likely causes ect. it would be really appreciated.
cheers
darren
Offline spudboy6
  • Just like a golf ......
Re: FAO VW or Bentley technicians
« Reply #1 on: 15 August 2012, 13:40 »
Buy a Haynes manual ;)
They fire hot air In to the engine to warm the cats up when cold , the pipes can become blocked or come
Lose on the drivers side I can't remember where they are as I haven't worked on a gt for a while but believe they run from the air box down by the front inter coolers
Check the pumps fuse but it's a job you need in front of you to diagnose tbh
But Vagcom reads the bentleys fully and you can run all the appropriate tests ect
« Last Edit: 15 August 2012, 13:43 by spudboy6 »
« Reply #2 on: 15 August 2012, 14:24 »
Do they do Haynes manuals for bentleys?
Fault code says bank 2, which I believe Is passenger side. Will check pipes and connections see off I can see anything
« Reply #3 on: 15 August 2012, 14:31 »
Don't suppose you have a rough idea of where the sensor?
Darren
Offline spudboy6
« Reply #4 on: 16 August 2012, 13:48 »
Darren
All I can remember the pump is down the o/s wheel arch , and there common for pipes coming of .
The Haynes manual I was pulling your leg about mate ,
Offline spudboy6
« Reply #5 on: 16 August 2012, 13:55 »
Darren
Gt's the last one I done , see the round pump behind the o/s inter cooler , that's the pump and filter that run up an go near that silver foil on the engine then the plastic pipes run over to the rocker cover on the o/s o the top of my head ,
There are several sensors round the maf and bottom of the inlet manifold . But get in there with brake cleaner spraying looking for air leaks
« Reply #6 on: 16 August 2012, 19:35 »
Briliant cheers mate, I'll have a look over it saturday
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 16 August 2012, 19:42 »
was the technical bulletin replacing the vacuum hoses to the combivalves at the back of the heads? if not, thats where i'd be looking first
you might find this useful too, not sure how much of it translates over to the twin turbo http://www.volkspage.net/technik/ssp/ssp/SSP_268.pdf
« Last Edit: 16 August 2012, 19:48 by topher »
« Reply #8 on: 16 August 2012, 20:27 »
It was something to do with pipes  :grin: don't know anymore than that to be honest. Will check all the pipes that I can see and get to, the code description says sensor circuit fault though, so think it maybe a sensor or wiring issue, will check on Saturday and see what I can see.
Cheers for the link will have a look at it
Darren
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 16 August 2012, 20:39 »
i didn't google the P code, i never trust those :grin: see if you can get a vag specific code out of it. if it is something in the circuit then you'll probably find this document more useful http://www.volkspage.net/technik/ssp/ssp/SSP_250.pdf
