Author Topic: Hurdy's Golf .:R - project 600bhp.  (Read 412400 times)
Offline Hurdy
Re: Hurdy's Golf .:R - project 500bhp.
« Reply #360 on: 26 February 2014, 17:39 »
Sooooooooooo :evil:
Dry today for the first time.
Seat Leon Cupra Black 290 DSG
Offline DCmk3
« Reply #361 on: 26 February 2014, 17:47 »
Time for some videos..  :laugh:
2014 Mk7 GTI - Littco L500
Offline Booth11
« Reply #362 on: 26 February 2014, 19:51 »
3.1 secs
Holy sh!t  :shocked:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hurdy
« Reply #363 on: 01 March 2014, 16:08 »
So, a week has flown by since the turbo kit went on and I can honestly say this is THE single most awesome modification I have ever done. The R is running better and stronger than it has ever done and all the logging that Steve  at Statller did when setting it up on the dyno shows that the car is running exactly as it should. Fuelling, timing and boost are all spot on and the car feels very smooth on the road.
Negatives?
The lag - It is there if you press your foot down in a high gear at low revs, but you'd be daft to do this. It takes a little adaptation and re-learning on how to drive with this set-up over my K04 or Loba set-up although the benefits far outweigh the momentary lag.
Launch control - More difficult to get just right, but you don't really need it as it will still do 0-60 in under 4 seconds without it!
Positives?
The power delivery - Relentless and sooo seductive, where the K04 starts to slack off at 6krpm, this set up simply pushes you back hard into the seat all the way to the redline.
Fuel consumption - Appears to be better.....unless you press the fast pedal.
Driveability - the car just feels better to drive for not having the huge hump of torque low down in the rev range, smoother and more linear. Part throttle is excellent.
Speed - The obvious advantage really. This thing hauls ass. Make no mistake about it a stage 2+R wouldn't see which way this car went. Conservatively speaking, this will now do 0-100mph in under 8 seconds. The quarter mile time should drop significantly.
Safety - Not one I would usually put down here, but it has to be said that overtaking is a breeze and it seriously reduces the amount of time you are on the wrong side of the road and exposed.
Noise - Goddam it this thing makes a sound like a jet fighter at full WOT!
Flames - I have them and it looks mental!
Cost?
Well for my specific set-up it isn't cheap, but something like a CTS kit with a GTX3067R would yield similar results running off the GIAC BT map and wouldn't break the bank.  :cool:
Offline Booth11
« Reply #364 on: 01 March 2014, 21:30 »
Sounds like a great improvement all round then, apart from a bit of low down lag.  And 0-60 in 4s without launch control!!  You must be very pleased with it . :cool:
Out of interest, what was the benefit of going with the Loba before the big turbo conversion?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hurdy
« Reply #365 on: 01 March 2014, 22:36 »
I wanted to see what the Loba would do as a modification to the R without going BT. It works very well as a fast road set-up as it has very little lag and climbs to big torque low down in the rev range. A BT R would have to be in the right gear on track to see off a Loba R. The Loba R would be more flexible.
On a sprint there would be no competition, The BT R would be faster as long as it can get the initial power down. :cool:
Offline Hurdy
« Reply #366 on: 03 March 2014, 19:20 »
A little clearer pic on the rollers
0-100..... Slightly uphill!
Offline Booth11
« Reply #367 on: 03 March 2014, 23:15 »
Not half bad going uphill then  :evil:
Still liking those flames.  What specific conditions are necessary to produce the flames?   Could they be replicated on a track or road?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hurdy
« Reply #368 on: 04 March 2014, 01:21 »
It maybe a dyno only feature unless I go WOT and then kick it into neutral on the road!!  :laugh:
Offline Diamond Hell
  • Opinions я Us
« Reply #369 on: 04 March 2014, 08:52 »
Coming to Germany this summer?  :huh:
