Author Topic: Hurdy's Golf .:R - project 600bhp.  (Read 412411 times)
Offline Hurdy
Re: Hurdy's Golf .:R - project 500bhp.
« Reply #330 on: 28 January 2014, 22:47 »
Car is booked in for the GTX3067R kit making next Monday. Bespoke tubular manifold with 44mm wastegate and custom 3.5" downpipe.
A few weeks without the R will be testing. :grin:
Seat Leon Cupra Black 290 DSG
Offline Hurdy
« Reply #331 on: 05 February 2014, 20:19 »
Slight edit......
HTA GTX3071. Custom Motorsport spec turbo. Got a little carried away when ordering. :wink:
Offline DCmk3
« Reply #332 on: 05 February 2014, 21:31 »
The bigger the better mindset?  :whistle:
2014 Mk7 GTI - Littco L500
Offline Hurdy
« Reply #333 on: 06 February 2014, 20:02 »
For this modification, yes. :evil:
The turbo is rated up to around 600 bhp, so it makes my 500 target easier. :wink:
Offline th3_f15t
« Reply #334 on: 06 February 2014, 21:37 »
Amazing car...
Moving over to Flickr, sorry for the broken picture links!
Offline Booth11
« Reply #335 on: 07 February 2014, 22:55 »
Slight edit......
Wow.  New 1/4 mile target on the horizon??
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hurdy
« Reply #336 on: 07 February 2014, 23:15 »
Slight edit......
Yep.  :laugh:
Offline Booth11
« Reply #337 on: 07 February 2014, 23:52 »
Slight edit......
Yep.  :laugh:
 :laugh:  you give nothing away
Assume you'll be getting it dynoed after.  Be interesting the see the results.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hurdy
« Reply #338 on: 08 February 2014, 08:04 »
Slight edit......
Yep.  :laugh:
Yes, and to keep it true it will be dyno'd at Statller as normal to see what the peak gains are over the L0400 and stage 2+ cars. :cool:
Offline Hurdy
« Reply #339 on: 18 February 2014, 10:29 »
So, I should have the R back for the weekend, just waiting on the TIAL housing to arrive from Owen Developments.
Final spec after much deliberation ended up being a bit overkill for how I am initially going to run it, but at least it will give me plenty of headroom for when pistons and rods are done.
Turbo kit specification......
Forced Performance HTA3071R turbo with TIAL .63AR housing. Turbo is a full Motorsport spec with all the FP options ticked.
Nortech custom tubular V-Banded manifold, fully CAD designed with external wastegate V-Band fitting.
Nortech custom 3.5" stainless steel downpipe with wastegate pipe plumbed in.
Turbodynamics 45mm external wastegate with 10psi spring.
All custom pipe work for cooling/lubrication.
As I mentioned, the turbo is a little OTT but has proven results on various cars over the GTX3071R and spool close to the GTX3067R. The turbo I specified will be initially run between 1.5 and 1.6 bar boost, which should achieve around 450bhp on Statllers dyno without WMI and in pump mode. For reference the L0400 using WMI, in race mode and at 2.1 bar made 369bhp on Statllers dyno, so I am looking at a peak gain of over 70bhp.
Longer term this turbo with supporting mods of pistons, rods, fuelling upgrades, intake manifold, cylinder head and cams will make over 550bhp, so should be a permanent fixture. :cool:
