Golf mk3
hardmonkeys
Breaks feel odd
Topic: Breaks feel odd (Read 2988 times)
stainesy
im not a master debater but i'm a cunning linguist
Re: Breaks feel odd
Reply #10 on:
15 August 2012, 18:15 »
Just went for a 50 mile drive. Brakes are a lot better but now the pedal has started to slowly sink again wile sat in traffic with foot on it.
What's going on?
Gavv8
Guest
Re: Breaks feel odd
Reply #11 on:
15 August 2012, 19:55 »
Sounds like a problem with the servo to me and its sucking air in to the system.
stainesy
Re: Breaks feel odd
Reply #12 on:
15 August 2012, 19:58 »
Great
That's all i need
Gavv8
Guest
Re: Breaks feel odd
Reply #13 on:
15 August 2012, 20:04 »
Not really behaving itself at the moment is it?
AcidicDavey
Here all the time
Not a VAG Owner.
Re: Breaks feel odd
Reply #14 on:
15 August 2012, 20:10 »
It sounds to me like the seal on one of the pistons in the master cylinder has gone. Is there any sign of fluid weeping from where it's mounted to the servo?
95 Volvo 480 2.0 Celebration
stainesy
Re: Breaks feel odd
Reply #15 on:
15 August 2012, 20:38 »
nope no fluid los at all.
how easy is it to change a servo or master cylinder?
AcidicDavey
Here all the time
Not a VAG Owner.
Re: Breaks feel odd
Reply #16 on:
15 August 2012, 20:47 »
The only hard part is the bleeding mate.
If air is getting in then fluid must be getting out, this is really strange! Have you checked the state of the vacuum pipe from servo to inlet manifold?
Last Edit: 15 August 2012, 20:53 by AcidicDavey
stainesy
Re: Breaks feel odd
Reply #17 on:
15 August 2012, 20:51 »
yes the pipe is fine. no splits or anything. i will have a propper check everywhere tomorrow to make sure but im pretty sure theres no fluid on or around it.
tweed
Forum addict
Re: Breaks feel odd
Reply #18 on:
15 August 2012, 20:52 »
Could be master cylinder
Could be sh!t pads even if they do look good. I had same problem and replaced the pads even though the pads on the car looked good and it made all the difference.
Could be a leak. Check rear brake lines. They are known for corroding.
Untitled
by
tweedub
, on Flickr
stainesy
Re: Breaks feel odd
Reply #19 on:
15 August 2012, 21:03 »
could anything to do with abs cause this? as the previuse owner has removed the bulb from the abs light.
Golf mk3
hardmonkeys
Breaks feel odd
