Author Topic: brake disc keep warping.  (Read 3504 times)
Offline km
Re: brake disc keep warping.
« Reply #10 on: 14 August 2012, 22:48 »
when you changed the discs last time did you clean the hubs down good? with a wire brush? also cheap discs do warp quick my 288 front discs lasted 5k now there warpped they were just gsf discs,pads, il be geting some ebc turbo discs when i can afford some :) there not drilled as ive heard many people moan about drilled discs as they crack
I'll give them a good clean when I fit my new discs. I'd be happy if mine lasted 5k  :grin:. And nah. Not into drilled :) think I'm gonna buy some plain ebc/brembo discs from badger5 and get him to groove them! Or just go for ultimax.
Bushes, tracking, ball joints, track rod ends, wheel bearings. All of these can cause a wheel to wobble. Sure you havent got a sticking caliper and causing one disk to get too hot? Coming to a stand still generally does it as it causes a heat spot.
All of the above have been replaced within the last few months and there is no play within the wheels. Pistons go in fine. But still gonna scrub them down when I next fit new discs.
Offline james2
  • No scammers please.
« Reply #11 on: 14 August 2012, 22:49 »
Any other suggestions before I splash out? :)
get drilled ones .My front brake was stuck on for god knows how long (wheel wouldnt turn jacked up), got a puncture fixed to find the alloy hot as hell and a bad smell from the pads. Mechanic said the groved and drilled discs help get rid of the heat. I fixed the caliper and disc was fine.  :drool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline km
« Reply #12 on: 14 August 2012, 23:03 »
http://honda-tech.com/showthread.php?t=2382409
Good read. Plain vs drilled.  :wink:
Offline Prawny
  • R-tech power!!!
« Reply #13 on: 15 August 2012, 08:42 »
Don't get drilled discs! Drilled are evil and crack.
Not really sure why you keep getting vibrations mate, sounds very odd to me. Are you properly harsh on your brakes?
Offline km
« Reply #14 on: 15 August 2012, 11:08 »
Wouldn't like to think so! Have never had any problems with discs before :undecided:
