Author Topic: Difference in these batteries  (Read 938 times)
Offline richw911
Re: Difference in these batteries
« Reply #1 on: 12 August 2012, 11:58 »
CCA is for good cranking ability It is the number of amps a battery can support for 30 seconds at a temperature of 0 degrees F until the battery voltage drops to unusable levels
 A 12V battery with a rating of 600 CCA means the battery will provide 600 amps for 30 seconds at 0 degrees before the voltage falls to 7.20 V
The more the better but any of the above will work fine.
I have the Mid Bosch one and it is ideal  :smiley:
« Last Edit: 12 August 2012, 12:02 by richw911 »
Offline AD1.8T
« Reply #2 on: 12 August 2012, 12:35 »
Cheers bud moneys tight at the sec so im just gunna get the cheapy with 25% off its only £40 with a decent warrenty and its not that cold down south  :lipsrsealed:
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #3 on: 12 August 2012, 12:54 »
I've had both of those Bosch ones and they are excellent
edit: just to add the S4 one is £54 delivered on ebay ;)
« Last Edit: 12 August 2012, 12:56 by Golf_GT_TDI »
Offline AD1.8T
« Reply #4 on: 12 August 2012, 13:09 »
If it was another month i would! The other ones £40 and a 2 min drive to ecP tomoz :)
