Author Topic: 1.8t into a 2.0  (Read 1908 times)
Offline mar_k
Re: 1.8t into a 2.0
« Reply #10 on: 11 August 2012, 08:47 »
Its more than likely I will just sell up.
I haven't tried auto trader yet. Only Ebay
Offline Rhyso
Re: 1.8t into a 2.0
« Reply #11 on: 11 August 2012, 09:32 »
Try Ad Trader and Gumtree too
Offline mar_k
Re: 1.8t into a 2.0
« Reply #12 on: 11 August 2012, 15:57 »
Cheers Ryso
Offline Chris.
Re: 1.8t into a 2.0
« Reply #13 on: 11 August 2012, 16:00 »
Sooo tempted to write a guide for people who want to stick 1.8T into a mk4.  Amount of times it gets asked and no one searches.
Click For Build Thread
Offline mar_k
Re: 1.8t into a 2.0
« Reply #14 on: 11 August 2012, 16:09 »
I had searched thank you very much!
Nothing seem to come up using the search function........... Im not that bone idle that I wouldn't have atleast tried.
Offline Chris.
Re: 1.8t into a 2.0
« Reply #15 on: 11 August 2012, 16:13 »
Wasnt directed at you personally.
Chances are, your 2.0 box will be 02J so you would probably be alright in terms of transmission as you can use your 2.0 setup.  You would need a new clutch to cope with 1.8T power, but a 2.0 clutch would more than likely bolt onto the 1.8T block, but soon die from the power.
Looms you will need the engine loom and the looms that go to the ECU.  Brakes would need upgrade and full 1.8T exhaust or something 2.25" bigger bore.
Offline ReDBull
Re: 1.8t into a 2.0
« Reply #16 on: 11 August 2012, 17:15 »
You could always do a K04 conversion at the same time. With the second hand prices of S3 and LCR being so low you could brake them for the parts you need and make money off what you don't want. Pick the right donor car and you could have 280bhp, big brakes and a leather interior. Depends if you have the time, money, skill etc.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
