Author Topic: 700 RPM at Idle?  (Read 4258 times)
Offline hobnobbob
Re: 700 RPM at Idle?
« Reply #10 on: 09 August 2012, 00:50 »
why dont you try putting everything to standard first before asking questions.
your ecu wont have a clue what to do without everything plugged in.
once you've done that replace the cheap bits first such as the water tempt sensor which can make running rough. a sticky idle controle valve sorted my idling issue but DONT buy a pattern part. either get a Bosche part from another golf or fork out for a new one the pattern parts are beyond sh!t.
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 09 August 2012, 18:57 »
the agg doesn't have an idle control valve. it's siemens/simos/hitachi injection
oh and it will run without a maf fitted or the air temp sensor fitted (I know cars which have had faulty maf's for years!)
Offline stainesy
« Reply #12 on: 09 August 2012, 22:35 »
I think my MAF is buggered. Tested it yesterday by having the engine running and unplugging it and plugging it back in and it made no diferance to the way the engine ran.
  • Back in a Mk3...
« Reply #13 on: 09 August 2012, 22:45 »
That's a good way of testing it, although proper vag-com can give live maf readings to make 100% sure (I'm sure someone knows what the readings should be?)
Offline stainesy
« Reply #14 on: 09 August 2012, 23:19 »
I keep meaning to get mine plugged into vagcom but don't no anybody with one.
Offline lars2.0
  • VW golf mk3 D.R.I edition
« Reply #15 on: 10 August 2012, 20:51 »
Sorry Mates but today I was changing the distribution strap. Now I going to answer all!
I have got no connected de Mass Aire and temperature because the car worked better..Now I don't know. Today  I done a travel of 140 km at 100km per hour..Normally do a 7'2 L/km... today at the same speed 9'2 ¬¬ WHY!?
Offline stainesy
« Reply #16 on: 10 August 2012, 20:57 »
probably because your car is maybe over fueling do to it not having a MAF telling the ECU how much air is going into the engine so it does not no how much fuel to use.
Offline lars2.0
« Reply #17 on: 10 August 2012, 21:01 »
Tomorrow I will install the original filter and  the mfa...
Anybody know what a hell is this?
Offline forsh
« Reply #18 on: 19 August 2012, 09:22 »
Normally it's arround 850/900 when it's at work tempetarute and when it's cold engine but Here we are at 35 degrees and ever works at 800 rpm...
Maybe it's a Dirty idle valve? where is it?
this it is my engine
Code AGG
i see the starter motor but wheres the engine
Offline forsh
« Reply #19 on: 19 August 2012, 09:23 »
could be charcol filter,it looks smaller then mine but ive a vr6
