Author Topic: FMIC choices and how to guide  (Read 89747 times)
Offline Dalo Harkin
Re: FMIC choices and how to guide
« Reply #20 on: 19 August 2012, 09:49 »
you mean K03s?
Offline paultownsend
« Reply #21 on: 19 August 2012, 23:47 »
Nope. Your Current k03. Like I have. Be interesting if it changes the boost characteristics and sustains boost
Offline jamie1989
« Reply #22 on: 20 August 2012, 11:39 »
The same probs.
K03 are very rare to go over 200bhp, K03s ftw
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Dalo Harkin
« Reply #23 on: 20 August 2012, 14:47 »
It definatley holds the boost better than stock setup, it wont be getting rr though, the K03s is going in and then the stage 2
« Reply #24 on: 12 September 2012, 10:57 »
Dalo
do you have any pics of the install? do the silicone pipes fit behind the normal bumper and vents?
Offline ReDBull
« Reply #25 on: 14 September 2012, 19:30 »
Well just got everything ready for fitting my FMIC tomorrow
The plan is the Wellycooler, oil cooler (not the pumbing though), LED side lights and re paint the front Brembos. I'll post up parts list and K04 fitting guild.  :smiley:
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 15 September 2012, 10:45 »
Pics of progress please :afro:
Offline ReDBull
« Reply #27 on: 16 September 2012, 20:11 »
So I've finally got around to fitting my FMIC this weekend. As our cars are slightly different and mines a K04 car. I'm not to sure the differences but I'll post my guild any way. They are copter and pasted from my readers ride. Hope this helps.  :smiley:
Offline ReDBull
« Reply #28 on: 16 September 2012, 20:12 »
As I've been up since 6:15 with the kids I thought I'd post a few photos. I've been reading about FMIC set ups and have decided to go with the Toyosports type B large IC. Known as the Wellycooer due to it's origins in the custom FMIC thread on ASN. I pored a link to ASN earlier in my RR.
It's a big core 600/300/76mm here it is sat in front of our dishwasher
 A link to where you can buy it. I paid £96 delivered.
http://www.toyosports.co.uk/intercooler-70-c.asp
On to the pipe work. I'm using 45 degree 76/63 mm silicone reducers either side from core.
http://item.mobileweb.ebay.co.uk/viewitem?itemId=290362072607&index=3&nav=SEARCH&nid=02221114485
Then 90 deg 63mm alloy beaded joiners (or I would be if I hadn't been sent stainless ones!!!)
http://item.mobileweb.ebay.co.uk/viewitem?itemId=270865713881&index=0&nav=SEARCH&nid=83301232105
Then 90 deg 63 mm silicone hose which then joins up     to the plastic map pipe on the passenger side.
http://item.mobileweb.ebay.co.uk/viewitem?itemId=160786524988&index=15&nav=SEARCH&nid=14320667086
To join up with the top turbo hose from the charge pipe you'll need a 63 mm short alloy joiner.
http://item.mobileweb.ebay.co.uk/viewitem?itemId=160516793157&index=2&nav=SEARCH&nid=62645597597
That's all the parts you'll need other that jubilee clips. I've avoided the T bar type clips as a few people have recommended not using them.  As there easy to over tighten and cause boost leaks by bending the alloy joiners.  But each to there own. Thanks to Dad I didn't  have to buy jubilee clips.
As I still have the original top turbo hoses. I've divided to replace the one from the charge pipe with a 45 deg 63 mm alloy joiner and a 45 deg 63mm silicone hose
You can buy these also from Mr Silicon.
The pipe work
The driver side pipe work.
The passenger side pipe work.
So that's the pipe work. Next was trimming the body work to get the core to fit as far back as possible....
Offline ReDBull
« Reply #29 on: 16 September 2012, 20:14 »
Next up was getting the core to fit and making beakers. Thanks to Dad doing this part.
A before photo
We spent a bit of time looking things over to decide ow to get the core to fit as far back as possible. We winter to do this to reduce the amount that needs to be trimmed from the bumper bar, bumper and hopefully allow re fitting of the fog lights.
Marked up ready for cutting
After cutting. My Dad used a thin wheel in the grinder.
The top of the core fitted nice and close the the air con vad. But the bottom could get closer. So a little more trimming was needed.
All marked up.
Then painted the bear metal
It fits nice and close now. About as far back as the core could go.
Next up was making so beakers for the bottom of the core. Dad used 6 mm aluminium bar.
Then it was the top brackets.
