Author Topic: lowered too much?  (Read 4483 times)
Offline Junior74
Re: lowered too much?
« Reply #10 on: 02 August 2012, 20:50 »
Nice!!! My front coilovers are all the way down, it'll be fine, gonna remove the helper springs next time i'm fiddling with it...my engine is on hockey pucks, that helps (alot), used to smash of everything!!!
do you puck each mount? I desperately need to do this  :grin:
Yes mate, I did them all...
Offline tweed
« Reply #11 on: 02 August 2012, 21:02 »
Looks as low as mine.
I have just put 195/40/16 Tyres on my 8" wide front rims that has lowered the front an extra 10mm and I now hit my subframe on the road all the time  :sad: had to drive to wells at 40/50. Did get 40mpg with a high lift cam though
Offline Junior74
« Reply #12 on: 02 August 2012, 21:10 »
'Good noise that is...'
Gavv8
« Reply #13 on: 02 August 2012, 21:16 »
Jeez, do you guys all live on a sheet of glass..... :grin:
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 02 August 2012, 21:26 »
Do you low guys take the front wheel arch liner out as mine rubs when cornering hard.
Offline leigh_harty
  • Audi AGU
« Reply #15 on: 02 August 2012, 21:28 »
They soon wear through  :grin:
Cheers mate, ill get some ordered :wink:
Dont lose your dinosaur!
Offline stainesy
« Reply #16 on: 02 August 2012, 21:32 »
my black mk2 was that low at the front my subframe was always hitting something even on a slitely wobly road you would hear scrap then a bang that scares the fcuk out of you specialy if you doing 80  :grin:
i had to take the vr front splitter off and put gti one on as the vr one would be scraping the road  :grin:
bottom of my subframe was bar metal if you looked under the car. :grin:
« Reply #17 on: 02 August 2012, 21:37 »
If the springs are loose you can now fail the mot.
Offline allsmiles
« Reply #18 on: 02 August 2012, 22:41 »
tweed is yours as low as mine or was it juniors?
Offline tweed
« Reply #19 on: 02 August 2012, 22:59 »
Mine and his are about the same
