Author Topic: Mk3 gti 16v project colour code  (Read 166100 times)
Offline murraymint
Re: Mk3 gti 16v project colour code
« Reply #160 on: 16 January 2013, 20:14 »
nice man! how does she run?
Thanks bud, she runs awesome!
nice work very good progress bet your happy can't wait to see it how you had it visioned :D
Thanks mike, yh I am can't wait to get all the little finishing touches done.
Sold my green golf today  :cry:I got a set of coilovers in with the deal so started stripping them ready to clean them up and fit them to the gti
Some other parts turned up also
Drivers door loom
Standard splitter
Had a little helper too
josh
Offline Bellend
« Reply #161 on: 16 January 2013, 20:18 »
How are you cleaning coils?
I found the best method was wire wheel on a bench grinder. Then put a nice amount of copper grease on the threads all the way up and wind up and down a few times. It's been sat for 4 months and I just raised it and fine. :)
Where all my moneys went.
Offline SoundillusioN
« Reply #162 on: 16 January 2013, 20:29 »
That's fine for a car that's not moving but for one that's on the move, you can't beat chain wax as it doesn't wash off.
Offline murraymint
« Reply #163 on: 16 January 2013, 20:29 »
Yh pritty much the same way, pritty supprised as none of the adjuster rings were seazed on so they must have been pritty well looked after before
josh
Offline murraymint
« Reply #164 on: 16 January 2013, 20:30 »
Chain wax you say?!
josh
« Reply #165 on: 16 January 2013, 20:36 »
Yarp.
Its meant for motorbike chains as obviously oil won't stay on for long at the speed they would be spinning at.  Set mine up to the height I wanted, sprayed chain wax on the whole lot and they're as mint now as the day I bought them.  Have adjusted since with no bother.  Plenty of people have suffered with seized rings after not being adjusted for long periods and going bone dry and rusty.
« Reply #166 on: 16 January 2013, 20:39 »
Another option for coilovers is to spray them with waxoil.
Offline JC
  • Back in the North.
« Reply #167 on: 16 January 2013, 20:41 »
Yarp.
may i suggest a DRY chain wax,  :wink:
no joke
Offline trog_nfs
« Reply #168 on: 16 January 2013, 20:42 »
Chain wax is a miracle cure, works on everything from coil-overs to pulleys
Offline murraymint
« Reply #169 on: 16 January 2013, 20:49 »
Yarp.
no joke
So I guess I'm buying some chain wax then.
Cheers guys!
josh
