Author Topic: MFA Display  (Read 6056 times)
Offline robw09
Re: MFA Display
« Reply #30 on: 10 August 2012, 15:52 »
Seen on another site that some people have a voltage regulator blow on the back of gauges.  No idea what type, or even it applies to VDO clocks, until I take a look.  However, may as well try.
Also where do the clocks earth to and how can you actually test an earth?  I need to learn this as it sounds quite important  :tongue: I have not got a voltage tester to hand, but I can borrow my dads at the weekend.
Offline weazgti
Re: MFA Display
« Reply #31 on: 10 August 2012, 19:27 »
Voltage regulator is a small chip with 3 pins on back of clocks.
Could check that all earths are on the earth claw above the pedals,not sure if they earth there but worth a look.Also the other earth point is above bonnet pull
Offline robw09
Re: MFA Display
« Reply #32 on: 11 August 2012, 15:08 »
No, it was just me missing fuse 16 had blown (thanks rubjonny and ken)  :embarassed:.  I now have working gauges and warning light, but still no MPG or miles travelled on the MFA   :rolleyes:
But at least I am rolling again!  :grin:
Offline X4MGS
  • VAG Parts SNOB!!!
Re: MFA Display
« Reply #33 on: 11 August 2012, 18:10 »
 :cool:
For More Info Click To See;
