Author Topic: Best Broadband Deal  (Read 4422 times)
Offline Rhyso
Re: Best Broadband Deal
« Reply #10 on: 01 August 2012, 13:31 »
The £6.99 per month is if you live in the low cost area  :smiley:
I've been with Plusnet for nearly 2 years now and haven't had a days trouble  :smiley:  Only ever spoken to customer services once and that was to setup the account!
Just recently upgraded to Plusnet Pro which gives you 60gig download limit for an extra £5 per month
I will look into Plusnet, have you had any issues with Xbox Live or is it pretty good? I've given up on Live where I am now as the net is so sh!t I can't be arsed.
Never had any issues with it; only issue I've had is the fact I live so far from the exchange that my download speed is around 3.5mb  :sad:  But that's because our exchange is in the dark ages despite the fact is slated for a major upgrade......
Offline Adam
« Reply #11 on: 01 August 2012, 13:32 »
PN have been very good and they have a range of packages available, have a look on their website  :wink:
Yeovil are getting fiber to the cab by 31st December 2012. If your wanting the quick speeds i'd go with BT then upgrade to Infinity when its available.
I wouldn't rely on sites like Samknows for FTTC availability, it says it's available in our area at work and has for the last year yet when we place an order with BT it fails because it's not actually available - same as for my home line on the other side of Oxfordshire :sad: which is why we went for a leased 100Mb (1Gb burstable) fibre line  :evil:
http://www.fibremap.bt.com/
Down Hill From Here.
Offline Shady Pioneer
  • graphic designer.
« Reply #12 on: 01 August 2012, 13:34 »
Sounds promising then, I'll have to check what the speed will be but should be decent enough with any luck. Worth going for the Pro service do you think?
Adam, I'm not too fussed about mega speeds, 6mb+ would do me fine, I currently share a 3mb connection with 6 other people!
Offline Rhyso
« Reply #13 on: 01 August 2012, 13:40 »
I've gone for the Extra @ £11.49 per month for the 60gig limit.  I also have phone calls with them and my bills are around £25 a month for the lot.  That's as long as Linzi doesn't natter for ages on the phone  :grin: :grin:
The connection has been rock solid in the time I've used it apart from perhaps 2/3 occasions where the connection has dropped for about 2-3 minutes.
Offline Len
« Reply #14 on: 01 August 2012, 13:43 »
Do you still have to have BT for line rental?
www.sas.org.uk
www.the-ace.org.uk
Offline Rhyso
« Reply #15 on: 01 August 2012, 13:51 »
All in with Plus.Net  :wink:
Little known fact is that Plus.Net is owned by BT........
Broadband - £11.49 per month
Uk Evenings & Weekends and line rental - £12.99 per month
Offline Len
« Reply #16 on: 01 August 2012, 13:58 »
FU*K!!!!
Wish I had looked into this a little more!
Cheers Rhys! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline Rhyso
« Reply #17 on: 01 August 2012, 14:04 »
FU*K!!!!
Cheers Rhys! :wink:
No worries  :smiley:  They might not be the cheapest about any more but for me the lack of hassle and trouble I've had its been worth it  :smiley:
Offline Jay
  • balding fat cvnt
« Reply #18 on: 01 August 2012, 14:12 »
[/quote
It uses the same BT database Samknows and the ISP's use, despite FTTC being "available" in Wallingford, it's not available in my part of Wallingford. All FTTC availability means is that the Exchange is FTTC enabled and the required % of the cabinets have had the fibre run to them. BT's fibre roll out sucks.
Offline Adam
« Reply #19 on: 01 August 2012, 14:13 »
[/quote
Understood :)
