Author Topic: thread of the week part deux  (Read 5788 times)
Offline cullygti
Re: thread of the week part deux
« Reply #30 on: 31 July 2012, 22:02 »
if i put bulbs in my headlights will they be brighter  :undecided:
Offline Dalo Harkin
« Reply #31 on: 31 July 2012, 22:11 »
depends if you close your eyes or not  :laugh:
Offline cullygti
« Reply #32 on: 31 July 2012, 22:16 »
what about taking my exhaust off will i get a better flow as theres no pipes for the gases to go through less travel means better yes
Offline DunnDeal12
  • Limited
« Reply #33 on: 31 July 2012, 22:34 »
correct
Offline cullygti
« Reply #34 on: 31 July 2012, 22:36 »
correct
knew i was right if the b!tches apprentice thinks so  :kiss:  :grin:
Offline rio_gti
« Reply #35 on: 31 July 2012, 22:42 »
If I connect the end of the exhaust to the tip shouldn't that help force air into the turbo making it spool even faster??
Offline cullygti
« Reply #36 on: 31 July 2012, 22:47 »
only if you fit a fan to cool the air or you will have heat soak i believe  :undecided:
Offline cullygti
« Reply #37 on: 31 July 2012, 22:52 »
if i put a diesel filter in my 1.8t will i get better mpg
Offline rio_gti
« Reply #38 on: 31 July 2012, 22:52 »
So rigging up the air con into it is what you are suggesting? Will it make the air cooler and denser than wmi
Offline tigerj360
« Reply #39 on: 31 July 2012, 23:01 »
If I blow into my air vents will it make the induction a lot better?
