Author Topic: vw golf mk4 upgrade spec  (Read 3094 times)
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: vw golf mk4 upgrade spec
« Reply #10 on: 27 July 2012, 16:29 »
Check these two guides out...
http://www.carbasics.co.uk/vw_golf_mk4_bora_vents.htm
http://uk-mkivs.net/forums/t/120319.aspx
or buy on ebay? I haven't seen one to verify quality of these though...
http://www.ebay.co.uk/itm/VW-GOLF-BORA-VENT-LOOM-RETROFIT-BORA-VENTS-OEM-LOOM-/150853275835
I'll be making my set 100% OE spec, as it happens I picked up a socket connector and pins today as I'm wiring in passenger door alarm LED to work with drivers one. As they are the same as used in Bora vents loom I'll post up a photo...
If you're able to crimp connectors its a no brainer to take this route over repair wires which need to be cut in half and extended anyway!
This loom tape may also be of interest...
