« Reply #31 on: 31 July 2012, 07:31 »
The Rio one was very obvious with the bouncer...can anyone explain the trick with the father and son where they pick a card at random from two packs of cards and they were the same? Both decks were shuffled, cards were all different...dynamo didn't touch them....
The easiest way I can think that was done was with two special decks of cards. I used to have some years ago, but I can't remember what they are called...anyway, they work by every card has the same one card (for e.g. 9 of spades) that is cleverly magnetised to the back. So no matter if you fan them out or flick through them the card you will choose is the same card.
pretty sure that it's a waxed deck he was using.
is that what the deck is called, I couldn't remember as I last had them over 20 years ago. I just remember that they had the same card that stuck to the back of the other cards.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
