Author Topic: 1.8 20v non turbo petrol smell  (Read 1196 times)
Offline sivrs
« on: 26 July 2012, 12:17 »
Just had a call off the missus to say her golfs struggling to start and when it does eventually go it stinks of petrol and has lost power.
I'm away at work till Friday so have any of you guys had the same or can you point me in the right direction as what to be looking out for when I get back.
Any help is much appreciated.
Si
Offline Dalo Harkin
Re: 1.8 20v non turbo petrol smell
« Reply #1 on: 26 July 2012, 12:45 »
if its taking ages then there will be more fuel, check the starter
Offline sivrs
« Reply #2 on: 26 July 2012, 12:52 »
She says it turns ok just takes a while to fire into life, sometimes it'll cut straight back out aswell.
Offline Dalo Harkin
« Reply #3 on: 26 July 2012, 12:56 »
could be the fuel pump, plugs, coils, starter.
Check it for codes and go from there..
Offline DunnDeal12
  • Limited
« Reply #4 on: 26 July 2012, 13:40 »
id say coil pack or sprak plugs
Offline CL-SID
« Reply #5 on: 26 July 2012, 20:45 »
its flooding with fuel by the sounds of it, so I'd start with the spark..
I want to be adored! - Oh, and I need one or two golf bits.
Offline sivrs
« Reply #6 on: 27 July 2012, 05:11 »
Managed to have a quick look, checked coils and there ok, changed plugs so I'll see what she says about it later.
