Golf mk4
Wazzzer
Window has dropped - Regulator questions
Topic: Window has dropped - Regulator questions (Read 2074 times)
bobbarley
Serious forum addict
I'm kind of a big deal...
Re: Window has dropped - Regulator questions
Reply #10 on:
25 July 2012, 22:50 »
I imagine you need to replace the speaker and tweeter together then?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #11 on:
26 July 2012, 08:16 »
I just replaced the lower speaker. Make sure you get one that that's quite bassy though
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
bobbarley
Reply #12 on:
26 July 2012, 19:43 »
This is how we do it
Steve_PD
Cruising around in a Land Cruiser
Reply #13 on:
26 July 2012, 20:00 »
Quote from: MC_PEA on 25 July 2012, 18:51
You would prob need to rivet them on because I would think a bolt mite get in the way of the window
Bolts are absolutely fine and the kit usually comes with bolts.
mar_k
Reply #14 on:
26 July 2012, 20:32 »
This is the ebay kit I have used on my gti, I have replaced both sides using kits
from this supplier and find them really good,
They will email you a video to show how to fit it aswell, however its not hard.
http://www.ebay.co.uk/itm/220685515016?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
bobbarley
Reply #15 on:
31 July 2012, 18:51 »
Bought and installed the kit from the guy you linked above.
Was really hard getting the last cable over the cam, managed it though. Both sides slide, but it's seriously tough to get them sliding, is that normal?
Feels like the motor will br doing a hell of a job to get them to move
mar_k
Reply #16 on:
31 July 2012, 19:02 »
The last cable is tough, It will only go over on the correct slide,
And yes they are quite tough to slide up and down due to the tension,
Its fine when fitted though. I have used 2 kits of him now and both have been great
bobbarley
Reply #17 on:
31 July 2012, 19:03 »
Cheers mate. Need the weather to be good so that I can fit it back into the car.
All being well might consider doing the drivers side as a precautionary measure.
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #18 on:
31 July 2012, 20:56 »
I did, and found it was just about to go too!
bobbarley
Reply #19 on:
11 August 2012, 17:33 »
All sorted. Put it back together earlier and it works really well! Makes a weird noise when it's going down though, sounds like the metal cable flexing about, works fine though
Golf mk4
Wazzzer
