Author Topic: Which Oil  (Read 2655 times)
Offline NobbyMk3GTI
  • Forums are always full of dicks!
Which Oil
« on: 25 July 2012, 18:22 »
What oil is best to use n 1.8t engine, how much should i put in after i change the Sump and pick up pipe? Also once the sump is off is the pick up pipe easy to change? Thanks for your help  :smiley:
Offline JimBR
Re: Which Oil
« Reply #1 on: 25 July 2012, 18:36 »
Quantum platinum from VW/TPS.
I think it's 4.5l but I put 3.5 in then keep checking the level and adding it bit by bit.
Offline NobbyMk3GTI
Re: Which Oil
« Reply #2 on: 25 July 2012, 18:57 »
Offline JimBR
Re: Which Oil
« Reply #3 on: 25 July 2012, 19:11 »
The pick up pipe is like 2 bolts that's all I think btw  :smiley:
Offline richw911
Offline shaft69
Re: Which Oil
« Reply #5 on: 25 July 2012, 20:58 »
4.5lt and i use 0/30w castrol edge.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline NobbyMk3GTI
Re: Which Oil
« Reply #6 on: 25 July 2012, 21:32 »
Offline daz veedub
  • Operation 1.8t bolf
Re: Which Oil
« Reply #8 on: 25 July 2012, 21:43 »
I use: http://www.vwspares.co.uk/product_info.php?products_id=1354 and that is the recommended spec as well (5/40)
Offline jamie1989
Re: Which Oil
« Reply #9 on: 25 July 2012, 21:43 »
10 40 for me used it 2 years an nearly 20k no issues.
I have an old AGU if it makes a difference.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
