Author Topic: Ths Intercooler fitted..  (Read 9009 times)
Offline rio_gti
Re: Ths Intercooler fitted..
« Reply #30 on: 20 July 2012, 14:52 »
Nice one, think sfs make custom silicone pipes so will get a price off them for the silicone pipe that runs in the crash bar as I can't find a 90 with long tails anywhere.......
Offline rio_gti
« Reply #31 on: 20 July 2012, 14:58 »
Also  when fitting do you uprate the charge pipe or the hose that goes to the pcr pipe? As surely this is a smaller bore than the ths pipe work!?
Offline jamie1989
« Reply #32 on: 20 July 2012, 15:06 »
No I dont think you do uprate them mate.
Looking at the kit online you get the core, pipe from core to throttle body, pipe from core to pancake pipe replacement and the pancake replacement.
I would prob think you would need a custom pipe made up unless you could have a join inbetween using 2 peices of silicone instead?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline rio_gti
« Reply #33 on: 20 July 2012, 15:11 »
Did think of doin this but didn't wanna risk havin a leak as it would be a nightmare.... But then could be the same said with the core connection as that would also be a problem to tighten?? (hidden in crash bar)
Offline DunnDeal12
  • Limited
« Reply #34 on: 20 July 2012, 15:22 »
try these rio
http://www.autosiliconehoses.com/
Offline jamie1989
« Reply #35 on: 20 July 2012, 15:23 »
Offline cullygti
« Reply #36 on: 20 July 2012, 15:30 »
try these rio
iv had a few pieces from them they pretty good  :cool:
if you use discount code from them you get 5% off
discount code is ashhoses
« Last Edit: 20 July 2012, 15:32 by cullygti »
Offline rio_gti
« Reply #37 on: 20 July 2012, 15:32 »
I ment once all on with bumper on etc...
Will look into it when the Internet is workin better wifi ain't the best here!!!
Offline Scott-R
  • GoT BoosT!
« Reply #38 on: 22 July 2012, 15:30 »
Having my ths front mount fitted soon.. Will you see a big difference?
Golf GTI ... What else would you have?
Offline shaft69
« Reply #39 on: 22 July 2012, 15:58 »
Has anyone measured intake temps with these coolers fitted??? Would love to know want compare with my tyrolsport SMIC.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
